'90 LX won't start, no crank.
Old 10-18-2012, 11:30 AM
DiBen
DiBen's Avatar
Default '90 LX won't start, no crank.
1990 LX (5-Speed)
The car doesn't crank when I turn the key, the only thing that happens is the RPM needle drops a bit, as well as the battery voltage needle, and my shift light will flash once. I get no other lights or electrical. Tried jumping the battery, doesn't work, only started when I run-jumped it.
I recently had the ignition lock cylinder, the ignition switch, and the alternator replaced, so it's not any of those. Any help would be appreciated!
DiBen is offline
Old 10-18-2012, 02:24 PM
Five0hFox
Five0hFox's Avatar
Have you tested your battery, cleaned your cable ends, and inspected for lose wires in the starting circuit?
Five0hFox is offline
Old 10-18-2012, 03:10 PM
javila2468
javila2468's Avatar
could be faulty starter solenoid.
javila2468 is offline
Old 11-01-2012, 04:17 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
by pass the switch on the clutch pedal and see if it starts...might have a bad switch down there
rmodel65 is offline
Old 11-02-2012, 08:48 AM
mustangsneverdie
mustangsneverdie's Avatar
^^^^ go with what he said
mustangsneverdie is offline
Old 11-02-2012, 10:53 PM
94redGTConv
94redGTConv's Avatar
is it ticking when you started? and is it efi or carberated? sounds like a starter or starter solenoid which is a super easy fix its on your driver side engine bay near the strut tower on the wall, I'd definately get your battery tested at autozone
Posted from MustangForums.com App for Android
94redGTConv is offline
Old 11-03-2012, 09:30 PM
billison
billison's Avatar
just jump the solenoid and see if it starts....
billison is offline
Granatelli Sales
01-20-2020 12:34 AM
1TUFF302
11-05-2015 04:02 PM
StalkerGT
09-25-2015 02:41 PM
MusicCity615
09-12-2015 07:05 AM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: '90 LX won't start, no crank.
