power windows issue
Old 02-25-2013, 06:45 AM
divercg33
divercg33's Avatar
Default power windows issue
my 89 gt convertible is having power window issues, the drivers side goes up and down just fine but the passanger and 1/4 windows dont move at all. I havent had much time to get into it because i work offshore so i am just looking for things to try when i get home. could it just be a relay? any information will help and thanks in advance.
divercg33 is offline
Old 02-25-2013, 08:23 AM
BabyGT
BabyGT's Avatar
Relay, dirty switch, dead motor, bad ground, loose plug, broke wire, I doubt it's a fuse as I would think all windows would be on the same fuse, but check that anyway.
BabyGT is offline
Old 02-25-2013, 08:56 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
if the 1/4 windows don't work, press the button and can you hear the motors run but windows go nowhere?? if so they sell abushing rebuild kit to fix 1/4 window motors = common problem
mjr46 is offline
Old 02-25-2013, 10:29 AM
divercg33
divercg33's Avatar
no when i press the button i cant hear a motor whine. and can anybody tell me where the relay is? i can have my son check that before i get home, its going to be his car anyway. and thanks for the replys.
Old 02-25-2013, 02:39 PM
BabyGT
BabyGT's Avatar
Relays are kinda hard to check besides just replacing and hoping that was the problem, check fuses and wiring and rule everything else out first.
BabyGT is offline
Nick Oliver
10-17-2018 04:22 AM
mustangchef
09-04-2015 08:08 PM
whatsup62
09-03-2015 01:38 PM
amandahchase
09-03-2015 10:09 AM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: power windows issue
