1995 Mustang 5.0 wont start.
Old 03-17-2014, 09:14 PM
electirc_5.0
electirc_5.0's Avatar
Default 1995 Mustang 5.0 wont start.
So I recently picked my first Mustang at a public auction. However I can't get it started. It needed a new Ignition lock cylinder, simple enough. Got that done but now when I try to turn it on it cranks and almost starts but I can't get it to start fully. What could be the issue? Could it have had an alarm and that's why I can't get it to stay on?
Oh Almost forgot
It's a 1995 Mustang GT 5.0 Convertible with a 5 speed.
electirc_5.0 is offline
Old 03-17-2014, 10:43 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
hold the accelerator to the floor and crank to stick the car in clear flood mode, if it still won't start, check fuel pressure, you'll need a gauge to do such for an accurate test, the test port is on the fuel rail, there is a capped off schredor valve
mjr46 is offline
Old 03-17-2014, 10:49 PM
electirc_5.0
I tried holding the accelerator to the floor and nothing.
Old 03-18-2014, 05:52 AM
dawson1112
dawson1112's Avatar
When you turn the key on do you hear the fuel pump prime in the tank?
Like mjr suggested , check fuel pressure at the rail when you turn the key on.
You should see at least 32 psi.
If you don't have enough pressure in the rail the injectors will just dribble fuel into the cylinders instead of atomizing it.
If you have good fuel pressure then next would be to check for spark at the plugs, and or coil.
dawson1112 is offline
Old 03-19-2014, 07:59 AM
Rice_Burner
Rice_Burner's Avatar
I got my 95 gt from my dads friend who got it in auction and then parked it... Sat for so long fuel pump went bad.. Would start it and it would start and turn right off... I changed fuel pump and fuel filter and it started right up... Good luck man
Rice_Burner is offline
BabyGT
BabyGT's Avatar
Pop trunk, under molding on the left side is a fuel inertia switch that cuts fuel in case of a wreck. Try pressing that. Might need to be reset, then go to what everyone else is suggesting lol.
BabyGT is offline
Old 03-19-2014, 11:56 AM
electirc_5.0
I just checked the pressure at the fuel rail and it's just 8 psi.
Old 03-19-2014, 12:22 PM
dawson1112
dawson1112's Avatar
Well that would be your problem then. You should have at least 32 psi .
Probly time for a new pump.
mstahoo
SVT Forums
08-19-2021 09:15 PM
Urambo Tauro
12-17-2016 03:30 PM
Urambo Tauro
09-07-2015 12:47 PM
'stangdude
08-12-2015 01:27 PM
daytooday
08-11-2015 09:22 AM
Quick Reply: 1995 Mustang 5.0 wont start.
