Backfire now no start
Old 02-19-2015, 10:13 PM
87gt347stoker
87gt347stoker's Avatar
Default Backfire now no start
Car was being driven under normal conditions and out of nowhere it backfired turns off and refused to start. The engine just cranks but will not start. I just got new plug wires and today picked up new plugs because the ones in there had been in there for a while.
The car is a. 347 stroker with elder rock heads and a blower. It's also efi. I'm really thinking the dizzy is toast but I'm not sure.
87gt347stoker is offline
Old 02-19-2015, 10:34 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
have you checked for fuel delivery/fuel pressure and or spark??....simple can of spray start can verify if it's a fuel issue...and a used spark plug or spark tester to check ignition
mjr46 is offline
Old 02-19-2015, 10:43 PM
87gt347stoker
I did check the spark, and fuel delivery. My fuel pressure stayed constant during the time of me trying to start the car. As far as spark, I pulled a plug wire off the top of the distributor to be sure it's getting spark and getting spark at the msd blaster. I also have a msd 6al both blaster and 6al have been on the car for a very long time.
Old 02-20-2015, 06:04 AM
dawson1112
dawson1112's Avatar
So you have spark and fuel, but do you have spark at the correct time? Maybe the distributor is loose and it moved, or hows your compression?
dawson1112 is offline
Old 02-20-2015, 06:39 AM
87gt347stoker
That's exactly what happened. The distributor was loose and moved now I'm unsure if that may have messed up the distributor. The motor has less than 5k miles on it. Another thing I'd like to ask is as far as firing orders, are there only the two different ones for ho and non ho?
Old 02-20-2015, 09:06 AM
dawson1112
dawson1112's Avatar
That's the only 2 firing orders I know of, your cam will determine what firing order your plugs are in.
Old 02-20-2015, 09:51 AM
87gt347stoker
Ok because when I bought the car the plug wires were totally different than both of those firing orders. If that's the case do I align the distributor with the number 1 plug in the other firing order?
Old 02-20-2015, 02:04 PM
87gt347stoker
I've been Turning the engine and I'm not feeling any air out the cylinder
Old 02-20-2015, 09:21 PM
mjr46
mjr46's Avatar
pull no 1 plug, roll motor over until you feel air come out with finger over the hole , at that point balancer and pointer should be close, lone up pointer to 0 on balancer, then drop dizzy in with rotor pointing to no 1 plug location on the cap
mjr46 is offline
zsmart
Convertible Tech
02-29-2016 08:33 AM
1TUFF302
11-05-2015 04:02 PM
StalkerGT
09-25-2015 02:41 PM
dalefrancis88
09-11-2015 07:15 AM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: Backfire now no start
