95 Gt Won't start sometimes
Old 02-14-2006, 04:30 AM
tx95gt
tx95gt's Avatar
Default 95 Gt Won't start sometimes
Please help This Car is driving me nuts. Sometimes it will Crank and run for awhile and then die. Somtimes it won't crank at all. I have had it towed 2 times and as soon as it came off the wrecker it crank right up. I have had the fuel pump replaced fuel filter replaced. new ignition module, injectors cleaned and check Mass air cleaned and checked. i have noticed when u crank it if the check engine line goes off it will crank if it doesnt u can crank it till the battery goes dead and will never crank.. thanks for any suggestion u might have
tx95gt is offline
Old 02-14-2006, 04:35 AM
Black Snake
Black Snake's Avatar
Default RE: 95 Gt Won't start sometimes
Might be a short somwhere. Check your lines.
Black Snake is offline
Old 02-14-2006, 04:53 AM
w8less
w8less's Avatar
my 95 did the exact same thing try this, ok get in ur car and turn the key like where the radio and things like that come on and count to like 10 and then try and cranking it. if starts its ur fuel pressure regulator
w8less is offline
Old 02-14-2006, 04:16 PM
95_302_StangMan
95_302_StangMan's Avatar
Check all the wires going to the starter, there is one black push on wire that if it is makeing a bad conection it wont crank or click at all. That was bad on mine. Just pull it off clean if off and put it back on if that fixes the problem then just cut the wire and put a new connector, and hook it up.
95_302_StangMan is offline
Old 02-14-2006, 07:37 PM
sc94gt
sc94gt's Avatar
The car has a computer. Plug in a code reader and see what comes up.
sc94gt is offline
Old 02-14-2006, 07:53 PM
fastang5.0
fastang5.0's Avatar
i had the same problem and i went to my local mechanic and he as well change every little logical thing he thought possible.. so i went to the ford dealer.. it end up being that a pick up sensor wasnt working.... i dont know if this can help u
fastang5.0 is offline
Old 02-14-2006, 07:58 PM
marx91
marx91's Avatar
could be the neg battery cable that goes down to the block, they are known for going bad
marx91 is offline
Old 02-14-2006, 11:32 PM
silver91gt
silver91gt's Avatar
check the wires to the plug for your coil power, 1 of mine was corroded and almost broken off.
silver91gt is offline
Old 02-14-2006, 11:35 PM
Kbush723
Kbush723's Avatar
i forgot to tighten a ground cable on my starter when i replaced my clutch that did the same thing some times it would start other times.. it would not..
Kbush723 is offline
Old 02-14-2006, 11:38 PM
silver91gt
silver91gt's Avatar
the cable going to the starter is a power wire, the ground for the starter is the block
Granatelli Sales
01-20-2020 12:34 AM
1TUFF302
11-05-2015 04:02 PM
StalkerGT
09-25-2015 02:41 PM
MusicCity615
09-12-2015 07:05 AM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: 95 Gt Won't start sometimes
