shorty or long tube headers
Old 01-14-2009, 10:55 AM
zippo2341
zippo2341's Avatar
i would wait fot the chip until you have some more motor work done, thats where youll see the most significant gain. shorties are nice, long tubes are better though power wise. to be honest i barely noticed a sound difference in my car after the shorties, maybe a little louder in the 2000-2500 range. with long tubes you will hear a difference. but keep in mind you'd have to change your x-pipe, and get the extenders for the 02 sensor. i passed new jersey inspection with my setup
zippo2341 is offline
Old 01-16-2009, 11:37 PM
minnow81469
minnow81469's Avatar
waterloo in the ghetto lol where when you bend a valve you cant fix it for a year
minnow81469 is offline
Old 01-17-2009, 03:09 PM
Tberg725
Tberg725's Avatar
Originally Posted by FORD TOUGH
With long tube's you will need a new x pipe and they will make it harder to work on (like replacing a starter). Shorties will bolt right up to the stock pipe.
Not if you have a mini starter.
Tberg725 is offline
Old 01-17-2009, 10:21 PM
95greengt
95greengt's Avatar
im runnin shorties on mine not a big diff in sound ... pretty easy to install ... but ive heard lts can be a b****
95greengt is offline
Old 01-18-2009, 09:14 AM
94StinkinLincoln
94StinkinLincoln's Avatar
plan on having to undo the motor mount bolts and raising the motor up to get them in and out.
i made the step up from shorts to longs, longs are a pain, things have the be clearanced and moved to make them fit, but will make more power.
94StinkinLincoln is offline
Old 01-18-2009, 12:12 PM
kweb288
kweb288's Avatar
it isnt to horrible to install them, just take your time and follow the instructions.
Lt's definitley sound meaner then shorties, i had both and definatley preffer the LT's. The long tubes produce more power because they PULL the exauhst gases out of the heads
kweb288 is offline
Old 01-18-2009, 12:20 PM
Explosive
Moderator
Explosive's Avatar
Longtubes make more power, but honestly, if you aren't looking for a headache and want something you can bolt on, get some shortties.
Explosive is offline
Jb145700
08-21-2022 06:37 AM
SSG Steggy
3.7L V6 Technical Discussions
11-05-2015 03:09 PM
Luke9222
10-22-2015 11:55 PM
PB Pod
Forum Issues and Feedback
09-17-2015 08:32 PM
BrantleyS550
09-14-2015 04:18 PM
Quick Reply: shorty or long tube headers
