What kind of replacement oil I can use for rear diff
Old 11-29-2010, 04:30 PM
Madman_DSM
Madman_DSM's Avatar
Default What kind of replacement oil I can use for rear diff
I would like to change it just in case, as there is a small leak I can't fix right now (no parts), but the owners manual has some cryptic FDxxxxxxx number which is 100% unlikely to be available in Europe.
Is there a replacement oil I could use, kinda like Dextron/75w90/ATF/someotherfancyname? I know the LSD is supposed to have special oil, but I don't know what index/name it should have.
Madman_DSM is offline
Old 11-29-2010, 06:58 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
75w/90 and a bottle of friction modifier or Limited slip additive
mjr46 is offline
Old 11-29-2010, 07:33 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
lucas makes some stuff that is already synthetic so, you wouldn't have to add anything to it. No idea how much it cost though. I used some stuff called posi trac and some cheap rear-end oil. It worked pretty good.
TrimDrip is offline
Old 11-29-2010, 08:20 PM
mjr46
mjr46's Avatar
I've used the posi trac stuff too = worked fine^^^^
mjr46 is offline
Old 11-29-2010, 08:37 PM
Bubba 95SN
Bubba 95SN's Avatar
+1+2 good information. That's all you need. You are really at such a disadvantage trying to get the things we take for granted. Hang in there. None of my business but what kind of tariff do you have to pay to get USA parts?
Bubba 95SN is offline
Old 11-30-2010, 03:06 PM
Madman_DSM
Madman_DSM's Avatar
Ok, I brought 2 liters of Castrol 75w90 LSD oil that goes into vicious coupling diffs, and from what I gather, it should be with additive inside. But after closer inspection, it turned out differential hasn't leaked any serious amount of oil. And I was under a false alarm. I'll leave those bottles for later, when I'll be replacing the axle seal.
The sound was coming from the front wheel bearing, so I'll have to replace that thing quite soon.
As for parts, last shipment from summitracing.com via USPS:EMS came out 165% of US price in total, custom charges and shipping included. Not very cheap, but UPS packages usually costed around 220%-250%.
Do summitracing stock OEM parts? I browsed but couldn't find most of what I need. I will have to write them I guess.
P.S.: Anyone has an idea why LSD is locking easily on left turns and almost never on right ones?
Old 11-30-2010, 05:34 PM
mjr46
mjr46's Avatar
try changing the fluid^^^^^^^^^if it continues the clutches are worn and need replacing
mjr46 is offline
Old 12-01-2010, 04:29 PM
Madman_DSM
Madman_DSM's Avatar
How do you drain the oil in the diff? Do you have to take the cover off? There was one more bolt, but I wasn't sure it's the real one, so I left it unchanged for now.
Aren't the clutches supposed to be slipping and grabbing equally in both directions?
Old 12-01-2010, 07:54 PM
TrimDrip
FudgeDrip
TrimDrip's Avatar
yes, the cover has to come off.
Not sure on the other question. If you change the fluid, it may fix the problem once that synthetic stuff gets on the clutches.
TrimDrip is offline
drfister
05-03-2018 10:38 PM
Urambo Tauro
Oil and Oil Related Topics
12-11-2017 07:16 AM
JonnyBlazeGT
11-03-2015 01:10 AM
Urambo Tauro
09-07-2015 12:47 PM
92 5.0stang
08-13-2015 06:46 AM
Quick Reply: What kind of replacement oil I can use for rear diff
