which throttle body and intake spacer?
#22
hld on hld on hld on, what i was saying is that venom said i should get a 65mm TB and a larger diameter MAF, and you (adder) said i should get a 70mm TB and just keep the stock MAF. But, what I was asking is that if i get a 65mm TB is it necessary to get a larger diameter MAF, or what....hope that helps
#23
Yes its true that a 70mm TB is "large" for a 302. It isn't going to hurt anything though. Also, down the road, should you decide to swap out your intake for... well... ANYTHING other than stock. A 65mm TB will be your new bottleneck.
Your car is stock... YOU DONT NEED A LARGER MAF
#24
dude, adder, i haven't said anything bad or derogatory towards you, and here you are venting and throwing a fit over nothing....not necessary at all
#25
venom doesn't know his *** from a hole in the ground. Yes its true that a 70mm TB is "large" for a 302. It isn't going to hurt anything though. Also, down the road, should you decide to swap out your intake for... well... ANYTHING other than stock. A 65mm TB will be your new bottleneck.
If you ask one more time about getting a larger maf... I will drive out to pennsylvania and push your car into a pond... Your car is stock... YOU DONT NEED A LARGER ****ING MAF
Luke9222
10-22-2015 11:55 PM
