Intake Question
Old 04-06-2008, 08:46 PM
drm_stang
drm_stang's Avatar
Default Intake Question
Hello Folks,
Fairly new here.
I have a 66 coupe with a 289 2v and I would like to change the intake and carb to a 4v setup. Found an old offy 360 single plane intake for a small block ford for a pretty good price but the guy is not sure of the deck size, also not sure if my 600 cfm Demon carb will work.. Has anyone used such an intake b4 on a 289??
ROb
drm_stang is offline
Old 04-06-2008, 10:27 PM
Starfury
Starfury's Avatar
Default RE: Intake Question
I'd strongly recommend against that intake on your engine. Single planes work well for high-rpm (ie. 6k+)use, but at the cost of low-rpm throttle response. Makes them great for built engines in strip cars, but not good for street cars.
Find a good aluminum dual-plane intake. The Edelbrock Performer Plus or Weiand 8124 would work great with your stock engine.
A smaller carb would also be a good idea. The factory Autolite 4100 is a good carb on a stock or mild 289 and it only flows ~480CFM. I wouldn't recommend anything more than 525CFM without some serious modifications first. Overcarbing can cause tuneability issues, specifically lack of throttle response at lower rpm's.
Starfury is offline
Old 04-06-2008, 10:53 PM
67mustang302
67mustang302's Avatar
+1
67mustang302 is offline
Old 04-06-2008, 11:00 PM
drm_stang
drm_stang's Avatar
Thaks for the advance guy, much appriciated... now what if i get some smaller jets and set the neddle lower for that particular carb?
Tivo304
08-28-2023 12:19 PM
Luke9222
10-22-2015 11:55 PM
Mustangmalo
09-06-2015 05:22 PM
Quick Reply: Intake Question
