harmonic balancer torque
how in the hell do you torque this thing?
a breaker bar got it tight enough to start spinning the engine.
its an auto so i cant put it in gear.
what would be the problem with hitting it with an impact wrench because that is the only thing i can think of that would tighten it.
RE: harmonic balancer torque
I think the spec is about 100ft-lbs. You got to put the hate to it but an impact wrench would scare me. It is bolting to the crank. If you screw something up, you are screwed.
i know, i have it as tight as i can get it and now the engine is spinning over with a torque wrench at about 40 ftlbs of torque.
but if i am at my wits end about how to torque this thing and i figure if i hit it with the impact in short bursts enough that i can turn the nut counterclockwise and it not break loose but spin the engine it should be good to go
i guess i could try bolt some flat stock to the pulley bolts and then bracing it against the frame or something but what a pita
i am assuming its in the car?
you could pull the starter and jam the ring gear with a big screwdriver but you'll need a mate to help.
I'm pretty certain the balancer only needs to be 60lbs so you're nearly there[8D]
ORIGINAL: Aussie66Fastback
looks like i am teaching wife to use a torque wrench.
unless i can talk her into crawling under the car with a big screwdriver
ORIGINAL: deadcarnahans
Pulling the access plate and jamming it there is easier than dropping the starter. Not?
You guys are making this WAY too hard, heh. Install two of the three (or 4, if it's a 68+) pulley bolts on the front of the balancer until they each stick out about 1-1/2". Finaggle a large pry bar in between them and use that as your leverage to hold the crank in place. Then you can torque away IIRC, torque is something like 90ft-lbs, but go get your shop manual out and double check:P
LivingInThePast
09-16-2015 12:20 PM
