Mustang Trans 3spd man. wont shift
If the shifter won't move even if you are trying that could mean one of the linkages on the tranny is stuck. We had this happen when we replaced my clutch and one of the linkages wasn't supposed to be where it was and locked up the shifter.
Sounds like the shift linkage is way out of adjustment. You need to get under the car, loosen up all the linkage, move the levers on the tranny until you get it into neutral, and then adjust the linkage at the shifter.
