1969 Mustang Grande- Horn relay location
i thought only the 19641/2 had horn relays ...
I checked on the 69 wiring diagram and I can't find a relay in there either.
it goes straight from the indicator/directional switch through the firewall to the horns.
if you want to check the horns, simply disconnect the cable on top of them (this assumes they only have one cable connecting to them) and run a temporary wire from battery+ to where the cable attached on the horn. the horn should beep. If not it doesn't have ground or is faulty
SANDY21
08-17-2015 02:41 PM
'stangdude
08-12-2015 01:27 PM
