Old 10-20-2015, 10:17 AM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Brakes
Print Wikipost
Brake lines- DO IT YOURSELF
Old 05-30-2012, 07:03 AM
Jonk67
Jonk67's Avatar
The bending part is easy with the right lines, the flaring is a skill you need to learn as the lengths vary so much you may need to cut/dbl. flare some. Oh and don't forget to put the fitting on before doing the flare. You can rent a good flare tool set from the parts store and return it for a full refund when done if you want to save money. Keep the first line you mess up on and practice dbl flaring on it. It has to be clamped TIGHT in the holder so it doesn't slip, I had to tighten with a crescent so it wouldn't slip down. You'll learn how far up to leave the tip (3/8"? on flaring instructions) for the first flare.
I used the new polymer coated lines (gray) from NAPA and they are the easiest to bend I have ever used and very forgiving of mistakes. They even had short lines with the 2 different sized fittings on each end I needed for the MC to dist. valve without cutting/changing fittings. I strarted the loop bends then switched to a 3/4" socket to wrap them around. I have never been able to bend a line in this tight of a circle w/o kinking. I ended up redoing all of my lines with the polymer coated.
1. keep your old lines for reference/ fitting size when buying.
2. I used coat hangers to make any different routes I wanted to for reference.
3. take your time bending and flaring, keep mistakes to practice on.
Jon
Jonk67 is offline
Old 05-31-2012, 11:06 AM
JMD
JMD's Avatar
Brake lines are easy enough to work from scratch, but since we are talking about a Mustang that has extensive aftermarket support, the pre-bent kits are cheap enough that you won't save a lot of money by bending them up yourself once you add up the lines, fittings, and tools required to do the job.
JMD is offline
Old 05-31-2012, 12:57 PM
goldrush031619
goldrush031619's Avatar
Thanks to everyone for all your input! I think I will listen to the majority here and try it myself.
-Joe
goldrush031619 is offline
b8checker
10-08-2015 12:55 PM
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
09-25-2015 06:42 PM
ThatJuanStang
09-25-2015 08:01 AM
Quick Reply: Brake lines- DO IT YOURSELF
