Can't keep 66' 289 2v running, but starts.
Old 07-20-2012, 07:57 AM
Pickles_99
Pickles_99's Avatar
OK, will grab one today. What should the pressure be?
Pickles_99 is offline
Old 07-20-2012, 08:44 AM
Pickles_99
Pickles_99's Avatar
And if you don't mind, how do you run the test? I am sure tester comes with instructions, but I'd like to hear how you do it. Thanks.
Old 07-20-2012, 02:50 PM
jlg2002
jlg2002's Avatar
I remove the hose that goes from the carb to the fuel pump preferably at the FP end and attach a length of hose to the FP outlet. You may need a nipple to connect the hose with. With that set up, place the other end of the hose in at least a 16 oz container. Start and idle the engine for 1 minute or until the container is full. specs are:
minimum volume: 1 pint in 20-30 seconds.
Pressure: 4-6 psi
jlg2002 is offline
Old 07-20-2012, 03:49 PM
RHuckster
RHuckster's Avatar
Carb. problem, floor jets plugged or the passages plugged, power valve not working.
Rick
RHuckster is offline
Old 07-23-2012, 08:40 AM
Pickles_99
Pickles_99's Avatar
I've come to the conclusion it is a dirty carb. Took carb off and started the rebuild process. Probably need to replace the tank as well, since it must be the source of the debris.
Old 07-30-2012, 08:30 AM
Pickles_99
Pickles_99's Avatar
Carb cleaned, reinstalled and runs well. Having an issue with choke linkage though. Does anyone have a good picture of what it should look like or know a site with good pics?
kdryan
08-21-2015 04:01 PM
KLS1968STANG
07-25-2005 05:44 AM
KLS1968STANG
07-21-2005 02:27 PM
mustang sally
04-06-2005 02:19 PM
4sale
01-01-2004 11:33 AM
Quick Reply: Can't keep 66' 289 2v running, but starts.
