Sponsored by:
Sponsored by: DashLynx
how to independantly wire a horn button
Old 11-07-2007, 09:16 PM
Lucas11
Lucas11's Avatar
Default how to independantly wire a horn button
How do you wire an independant button to the horn? I got in an accident and now my horn doesnt work, and im not trying to drop a bunch of money to get it fixed. So has anyone done this? I need it to pass inspection. Thanks in advance.
Lucas11 is offline
Old 11-08-2007, 06:03 AM
corvetteguy
corvetteguy's Avatar
Default RE: how to independantly wire a horn button
You have to find out if it is the horn, the relay,
or the horn switch.
You can get to the horn an put 12 volts to it
and see if it works.
You can get to the fuse and check it out.
You can listen for the relay to click
when you push the horn button.
You can remove the horn switch
and manually short it out to ground and
see if that works.
corvetteguy is offline
Old 11-08-2007, 06:49 AM
Lucas11
Lucas11's Avatar
thanks for the advice, Ill be sure to check all these areas, and hit up the forum again for further instruction.
Lucas11 is offline
jwog666
12-27-2021 08:09 PM
lincolnshibuya
07-05-2020 03:05 AM
firehorse02
11-16-2015 11:28 AM
lincolnshibuya
10-06-2015 08:45 AM
Dathan
10-05-2015 05:52 AM
Quick Reply: how to independantly wire a horn button
