Sponsored by:
Sponsored by: DashLynx
lumpy lopey camshaft noise the rowiest possible sbf
Old 12-01-2008, 07:58 PM
Hamutoff
Hamutoff's Avatar
Exclamation lumpy lopey camshaft noise the rowiest possible sbf
how do you make an engine lope the max possible?
mileage nor power matters here, please dont ask why...
-cam: narrow lsa (def not a wide lsa right?)
-cam: lots of duration, or is narrow lsa more important
-heads: smaller or larger heads? (more restrictive or better flowing all else being equal)
-displacement: less or more cubic inches (less right? 289 more lopey than 331 all else equal)
-other ideas
so would the best way to make lumpy idle: 289 with xe274 cam with tiny heads? mismatched sure but is this the ticket to a shaking car with stinky exhaust?
Hamutoff is offline
Old 12-01-2008, 08:06 PM
Bullitt2theHead
Bullitt2theHead's Avatar
Easiest way to make a lumpy idle-take off a vacuum line! yeah i see morons doing this to make their car "cam"...
a narrow LSA will give it that "blurmp...(five seconds later)...blurmp" kinda lope.
My curiousity is killing me-WHY?
Bullitt2theHead is offline
Old 12-01-2008, 09:11 PM
Hamutoff
Hamutoff's Avatar
why? there are many people (not me!) that want sound before performance. My goals for my 2 notchbacks are
1)more gas miliage than stock
2)best combination of power with efficiency to make a fun bracket car
in building #1 I figured less CI = more MPG, so reused my 1967 crank and rods on a 5.0, then I tried to figure out what cam to use - it is here that I learned that the less cubic inches the more "rowdy" a cam would act/sound... I had gotten the holley systemax 1 kit: lower intake and a cam just like FMS "E" cam but with more lift...
LUN51026 110 lsa, 281 adv, 220@ .050, .512"
FMS E 110 lsa, 282 adv, 220@ .050, .498"
either of these cams would be quite lopey on my 289 HO esp the Lunati/Holley this got me to thinking: what other factors actually make an engine sound lopey?
It seems that SMALLER displacement, with TIGHTER LSA... and then Im not too sure; it seems that QUICKER ramps on the cam but not always MORE duration, however a TIGHTER LSA combined with other varaibles that net more OVERLAP would make for more lopeynesss, but I have heard BOTH a more restrictive head and a better flowing head will combine with the other points already mentioned to make it more lopey but IM NOT SURE on this point
Mostly I am curious but knowing about this will increase my knoweldge of engines. I ended up buying an ISKY cam that had one of the smallest overlap #'s I could find:
ISKY 371252 intake@0.50: 204 exhaust@0.50: 210
intake lift0.465 exhaust lift 0.48
intake adv: 252 exhaust adv:
257 112 LSA 30.5 Overlap
for comparision SD stock overlap = 36^
MAF stock overlap = 39^
1993 cobra overlap = 33.9^
Hamutoff is offline
Old 12-02-2008, 02:11 AM
83gtragtop
83gtragtop's Avatar
You should post this in the 5.0L section.
83gtragtop is offline
bjdutch2005
03-24-2017 03:38 AM
KingRando
10-02-2015 08:06 AM
NYstang
09-30-2015 09:56 PM
Ghost_Conscience
09-23-2015 02:17 PM
Quick Reply: lumpy lopey camshaft noise the rowiest possible sbf
