Sponsored by:
Sponsored by: DashLynx
what is the switch
Old 03-03-2013, 01:54 PM
Thetrailrhitch
Thetrailrhitch's Avatar
Default what is the switch
I just bought a 2002 mustang gt. I have a rocker switch next to my coin slot in the console. I have no idea what it does. Its not fog lamps have another switch for that.
Thetrailrhitch is offline
Old 03-03-2013, 06:19 PM
96t-bird
96t-bird's Avatar
Hi, welcome. Post pics. We can try to help you.
96t-bird is offline
Old 03-07-2013, 03:50 PM
AutoPart-Performance
Former Sponsor
AutoPart-Performance's Avatar
Like 96t said, a picture will help. Are you sure it's not a dummy switch? I'd pull the switch and trace the wires using a volt meter. Shouldn't take very long. With the key on, hook one lead to each side of the switch. You should most likely have 12 volts. Now start pulling fuses, one at a time until you lose the 12 volt reading. Now you know what circuit the switch is one and it should be pretty easy to trace from there. Hope this helps. From your friends at www.autopart-performance.com.
AutoPart-Performance is offline
Old 03-07-2013, 04:54 PM
Det.FrankBullitt
Det.FrankBullitt's Avatar
Could be a kill switch. Try starting the car then turning the switch on & off.
Det.FrankBullitt is offline
Old 03-11-2013, 10:57 AM
andddrew
andddrew's Avatar
starting the car then turning the switch on & off will be fine to go with.
andddrew is offline
lincolnshibuya
07-05-2020 03:05 AM
PaulH2
20
01-31-2016 09:48 AM
jhawkr
10-30-2015 01:55 PM
guitarman376
09-30-2015 05:54 PM
Colin Ringle
09-15-2015 09:27 PM
Quick Reply: what is the switch
