Sponsored by:
Sponsored by: DashLynx
66' Mustang's solenoid's up in smoke?
Old 11-03-2005, 12:38 AM
c_los
c_los's Avatar
Default 66' Mustang's solenoid's up in smoke?
Hi, Im a newb w/a newb question.
I had my 66' stang sitting in the garage for like 2 or 3 months. When I go to start it, I can't. I take the battery to Pep BOys and they tell me I need to replace it; so I do. I'm ready to start the car now w/my new bat. When I do I hear the starter turning and I see sparks and smoke coming from the starter relay switch. Then everything goes dead and nothing happens when I turn the key.
So... instead of reading up, I go and buy a new relay (dumb, I know). When its all installed I go again to turn my car on and boom, same thing happens.
Im sure there's simple tests I can run and it doesnt seem like hard work to get it fixed, but I just need to know where to start???
Thanks in advanced people.
c_los is offline
Old 11-03-2005, 08:08 AM
03YellowPony
03YellowPony's Avatar
Default RE: 66' Mustang's solenoid's up in smoke?
First off, make damn sure the ground connection from the battery is bolted to your ENGINE block. If that's good, I would look at the positive connections to your starter solenoid. Make sure they are correct, and tight. If those are good, I would look at replacing the starter solenoid. May be shorted internally. And if those don't solve the problem. look at the starter. It can be shorted internally also.
03YellowPony is offline
Old 11-03-2005, 09:22 AM
Soaring
I ♥ Acer
Soaring's Avatar
Take your starter out, and take it to autozone or pepboys or whomever and have them test it. If it is OK, then make sure all your connections are clean and tight. Then, put on your new relay (we call it the solenoid) and see if you have success.
Soaring is offline
Old 11-03-2005, 12:59 PM
Tim37
Tim37's Avatar
ORIGINAL: Soaring
yeah sounds to me like there might be a starter problem.
Tim37 is offline
Old 11-04-2005, 12:54 AM
c_los
c_los's Avatar
Thanks guys.
Im pretty sure its not the solenoid seeing as the same thing happened to the new one I bought. I am gonna take the starter to Pep Boys though and see whats up w/that.
Thanks again.
c_los is offline
NorthAmericanTuning
03-18-2016 11:21 AM
MustangHead91
08-23-2015 09:37 PM
daytooday
08-11-2015 09:22 AM
Mnuckolls
08-09-2015 08:54 AM
Quick Reply: 66' Mustang's solenoid's up in smoke?
