bone stock mustang GT
Old 11-08-2007, 08:42 AM
  #31
TPony
TPony's Avatar
Default RE: bone stock mustang GT
Congrats on your purchase.
TPony is offline
Old 11-08-2007, 09:15 AM
  #32
22kart22
22kart22's Avatar
Hhhehe exactly!!!!!!! Engine swap ftmfw!!!!!!!!!!!!!!!!!!!!: D
ORIGINAL: 06Saleen3V
ORIGINAL: 22kart22
Can somebody say........
2.8 L BLOWZILLA??????????????
That zo6 will be so far behind, you won't be able to see it
They dont make them for the S197 3V's...those are for the GT500 platforms...
22kart22 is offline
Old 11-08-2007, 02:34 PM
  #33
06Saleen3V
06Saleen3V's Avatar
Hahaha ^ funny Kart
06Saleen3V is offline
Old 11-05-2008, 02:45 AM
  #34
SpunkyQ8
SpunkyQ8's Avatar
Wink Semi Final Project Car !
Hey guys,
Remember When i first asked what setup should i go for and how do i start my project "you can always go back to the first page and check out my inquiries "
Well Here's my semi final project out come !
Engine :
-MMR Cast Iron stroked 5.0 short block, with 9-1 Compression, Ceramic piston coating
-D1-SC Procharger @ 12 Psi
-Ported heads
-Charge motion Delete Plates
-XFI VSR Stage 3 Comp Cams
-Cam Phaser kit
-Manley Valve springs
Exhaust:
-Kooks Headers
-Corsa Sport Cat-back (extremely LOUD)
Cooling:
-Meziere electric water pump
Fuel System:
-Twin Shelby GT 500 pumps
-40 amp Kennebell boost-a pump
-60 Lb. Injectors
Transmission:
-Stage 2+ Spec Clutch With Aluminum Flywheel
-B&M Short Shifter
-Ultra light aluminum drive shaft up to 1000 Hp
Suspension:
-BMR Lower and Upper control Arm
-BMR Front and rear Sway bar
-Tokico front and rear adjustable struts and shocks
-Lowering Springs
-BMR Adjustable Panhard Bar
Body:
-3D Carbon 10 Piece body kit
-Cervinis 3 Piece rear wing
Wheels and Tires:
-19x9 front and 19x10 rear nitto invo's at the rear wheels only
Numbers:
-570 RWHP and 502 Torque
-DynoJET
-Tuned by Angry Camel (Saud Alzabin) !
Bear in mind i'm still working on the following : transmission planning on a 6spd manual, Fuel lines, and a new pulley from Reichard is on the way and some minor mods to the heads.
Check out my profile to see pics of my car
Thank you all for your opinions that helped this happen,
SpunkyQ8 is offline
Old 11-05-2008, 02:56 AM
  #35
Hufenstang
Hufenstang's Avatar
very nice man! I just swapped in the 6 speed manual into my car and i LOVE it.. you wont regret it at all.
Hufenstang is offline
Old 11-05-2008, 02:57 AM
  #36
SpunkyQ8
SpunkyQ8's Avatar
Yeh it's pretty crappy with my i can't shift to 5th gear !! i max at 4th only !
SpunkyQ8 is offline
Old 11-05-2008, 03:02 AM
  #37
Hufenstang
Hufenstang's Avatar
ya im using 4.10 gears in the 6 speed tr6060 out of the shelby/vette/viper with your power your stock transmission wont last too long, mine sure didnt!
Old 11-05-2008, 03:07 AM
  #38
SpunkyQ8
SpunkyQ8's Avatar
I have my 3.73 gears ready for my 6 spd :P, where do u recommend to get that tranny from ?
SpunkyQ8 is offline
Old 11-05-2008, 03:10 AM
  #39
Hufenstang
Hufenstang's Avatar
http://www.ddperformance.com/05-08%2...peed%20Kit.htm
they sell the complete kit, with everything you need to bolt it right in.. its really the only place that sells it as a complete kit that im aware of.
Old 11-05-2008, 03:11 AM
  #40
SpunkyQ8
SpunkyQ8's Avatar
Thank you
SpunkyQ8 is offline
Urambo Tauro
12-17-2016 03:30 PM
ding56
08-14-2015 02:40 AM
jink21
08-13-2015 04:33 PM
'stangdude
08-12-2015 01:27 PM
daytooday
08-11-2015 09:22 AM
Quick Reply: bone stock mustang GT
