Noise and "issues" from the rear...
Old 08-17-2014, 11:49 AM
Keep it real
Keep it real's Avatar
Default Noise and "issues" from the rear...
So about 2-3 weeks ago I got new wheels and a panhard bar was supposed to come with it, came a week later, but after I put the wheels on I've noticed a substantial amount of thuds/clunks when going over even the smallest bumps. When coming to a stop sometimes it feels like the rear axle is "skipping" so to say. The panhard bar is tight and nothing else is loose. Wheels are on properly and I can't figure out what it is. I haven't taken it to a mechanic yet. Just thought I'd ask here first and see if it was an easy fix or not. As always suggestions are appreciated!
Keep it real is offline
Old 08-25-2014, 01:16 PM
moochman4life
moochman4life's Avatar
Hey man, is the bar adjustable?
moochman4life is offline
Old 08-25-2014, 01:18 PM
moochman4life
The adjustment "nut" came loose on mine once, and it made all kinds of annoying racket. It can be hard to tell right off the bat if it's loose until u put a wrench to it.
Old 08-26-2014, 06:46 AM
Keep it real
yeah it's the SR adjustable bar. By the nut are you referring to the bolts that screw into both ends or the nut on the bolt that holds the bar in place? Thanks!
Old 08-26-2014, 03:07 PM
moochman4life
The one in the middle, that screws into both "rods".
Old 08-27-2014, 07:14 AM
Keep it real
ok I see what you're saying. I'll check it later. Thanks!
bjdutch2005
03-24-2017 03:38 AM
KingRando
10-02-2015 08:06 AM
Ghost_Conscience
09-23-2015 02:17 PM
ccdguy
09-19-2015 05:20 PM
Quick Reply: Noise and "issues" from the rear...
