Go Back   MustangForums.com > Ford Mustang Tech > 5.0 Mustang > Speed Density/Carb/SSP section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 05-23-2009, 10:36 PM   #11
AdderMk2
MF Attention Whore
AdderMk2's Avatar
Vehicle: 1994 Ford Mustang Cobra
Send a message via AIM to AdderMk2
with the amount of work you seem to have into your car at the current time. It would be il advised for you to swap to carb now.
you will have to buy a carb, manifold, fuel pump, probably have to convert your fuel lines, a new distributor, a different pick up in the gas tank.
when all you need to do is buy a set of 30# injectors
__________________
Siggy removed by Administration.
The Man is trying to oppress me...
AdderMk2 is offline   Reply With Quote
Old 05-23-2009, 11:06 PM   #12
67mustang302
Vehicle: 67 Mustang Coupe
Plus the carb will have additional cost of jets, air bleeds, power valves etc to tune it correctly.
__________________
Who cares how much horsepower it has, all that matters is how fast it goes!
13.20's with 2.25-2.30 60's, 40+ year old suspension sucks!
Best trap 107.11mph, we'll see what the new intake/carb setup does.
12.80 at 110.5mph NHRA DA corrected
67mustang302 is offline   Reply With Quote
Old 05-24-2009, 10:57 AM   #13
kremer306
runs great on 19 lb injectors with fuel pressure cranked up but when i swap to 24s an diff mass for 24s runs like crap powerless pretty much im tired of buying the same parts but diff brands to fix the prob and still runs the same w/ 24s. spending the money on a setup that will work doesnt bother me. i have a buddy that tunes carbs the last on he did was for a supercharger
__________________
91 vert with 10 pt cage sn 95 brake conversion strange struts currie 9 inch rear end 4.30 gear spooled qa1 rear shocks adj upper lower control arms 306 BLOCK alm heads trick flow upper lower intake trick flow stage 2 cam timing 15 advanced bbk fuel pressure regulator bbk 70 mm throttle body alum. radiator elec. fan msd ingnition.
kremer306 is offline   Reply With Quote
Old 05-24-2009, 11:18 AM   #14
AdderMk2
MF Attention Whore
AdderMk2's Avatar
sounds like you have all the right parts already kremer... you just need to figure out why its not right. Throwing parts at a problem isnt going to make it any better if you dont know WHAT is causing the issue.
Whats your fuel pressure at, what MAF are you running?
__________________
Old 05-24-2009, 12:12 PM   #15
kremer306
when i had the 24s in i ran it from low 30s to 40 psi i have a pro flow calibrated for 24s
__________________
Old 05-24-2009, 12:17 PM   #16
kremer306
their aren't any tuners around where i live so it makes it hard to figure out. and when i call diff co. all they want to do is sell me same parts diff brands im tired of messing with it and if i had a carb i could have i tuned alot easier. ya may cost more but if it works out i can sell my setup get money back
__________________
1995, 289, 94, 9495, 95, carb, carburetor, conversion, efi, fuel, gt, mustang, pump, sale, swap
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
