Speed Density/Carb/SSP section This section is for the Speed Density or Carb vehicles, as well as Special Service Package 'Stangs
throttle body Question?
Old 11-25-2010, 10:06 AM
88GT_ritchie
88GT_ritchie's Avatar
Default throttle body Question?
i have an 88 gt with speed density and i was still wondering if a bigger throttle body we also be ok without the maf? and what are some of the small tricks that can be done to this engine for more horse power without the maf? thanks everyone for your input
88GT_ritchie is offline
Old 11-25-2010, 11:45 AM
JPJP
JPJP's Avatar
The only thing Speed Density cares about is the cam. The larger throttle body is fine. You can change the other stuff without any drivability issues including supercharging.
Have you already removed your air intake silencer? Remove it for a little HP. Add a performance air filter.
Port or get a ported lower intake manifold if you ever take it off for any reason such as changing/upgrading heads.
Bump up the timing to 14° BTDC if you haven't already. Get an aftermarket chip maybe. Toss on a MSD ignition box for improved efficiency and better emissions.
JPJP is offline
2tonterror
2tonterror's Avatar
Hi. A 65MM tb would work fine. It is only worth a couple of horsepower unless you do other mods. Basic mods such as a Cobra intake, shorty headers, u/d pullys, cold air kit, etc will all add hp. I run a Crower cam and a set of ported E7 heads w/speed density. Hope this helps. Mike.
2tonterror is offline
Luke9222
10-22-2015 11:55 PM
94stangnewbe
V6 General Discussion
09-07-2015 07:39 PM
Webster454
09-07-2015 04:59 AM
Mustangmalo
09-06-2015 05:22 PM
Quick Reply: throttle body Question?
