Add TPMS?
Old 03-20-2014, 01:56 PM
ColinW627
ColinW627's Avatar
That would be ideal if they are requiring TPMS sensors now. Its a great feature but more specific information would be great. Would at least be cool if the GT's or premiums had that feature.
ColinW627 is offline
Old 08-30-2014, 08:23 PM
bfunke
bfunke's Avatar
The sensors must match the receiver on the vehicle. FoMoCo OEM sensors were mounted on a band around the rim. You can get replacements mounted to the valve stems. I think those are available with compatible transmitters. The sensors have a battery similar to the key fob so they will only last 5-8 years. Rock Auto lists both styles.
bfunke is offline
Old 09-01-2014, 10:20 AM
157dB
Cut & Paste Expert
157dB's Avatar
The 05-09s used the OEM band sensors.
The 2010-14s use the OEM valve mounted sensor.
The two are not interchangeable whatsoever.
Put your old 05-09 band mounted TPMS sensors
in a sealed PVC tube, air it up to 36 PSI
and throw it in the trunk.
The TPMS system will be happy forever more.
157dB is offline
Old 09-01-2014, 12:52 PM
Nuke
Nuke's Avatar
Originally Posted by ColinW627
Nevermind.. a day later my car is mad at me because there are no sensors to read...
That was going to be my post when I read this but you beat me to it with your next post. It often takes a trip or 2 for the TPMS to realize it's not getting a signal. Personally, I'd rip the darned system out. Other than reminding me when one of my SUV's has a spare with low pressure, it's a PITA. But that's just my 2 cents.
Nuke is offline
jwog666
12-27-2021 08:09 PM
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
LiquidDrink
09-29-2015 10:06 AM
wraith777
09-28-2015 10:49 AM
Sminemann
09-17-2015 09:24 AM
Quick Reply: Add TPMS?
