Trunk Retainer nut fix
Old 10-05-2015, 05:31 PM
tradosaurus
tradosaurus's Avatar
Default Trunk Retainer nut fix
I saw this on a previous post and thought I would post again.
The rear trunk trim panel is held on by 4 plastic clips and 2 plastic retainer nuts. The retainer nuts eventually strip and cost about $10 each.
A more permanent fix is to use a metal coupler nut and a metal elevator bolt that can be found at Lowes or Home Depot.
The Hillman Group 2-Count 1/4-in Zinc-Plated Standard (SAE) Regular Nuts Item #: 142056 | Lowes Model #: 881650
The Hillman Group 2-Count 1/4-in to 20 x 1-in Zinc-Plated Elevator Bolts Item #: 137972 | Lowes Model #: 881003
The coupler nut will thread part of the way on the existing bolt as the bolt is metric but it holds nicely.
Total cost: $4.50
Attached Thumbnails Trunk Retainer nut fix-coupler_nut_1_4.jpg   Trunk Retainer nut fix-elevator_bolt_1_4.jpg   Trunk Retainer nut fix-rear-trunk-trim-panel.jpg   Trunk Retainer nut fix-2005-09-mustang-trunk-trim-panel-retainer.jpg
tradosaurus is offline
WJL
02-26-2018 01:39 PM
dkpGTCS
10-04-2015 08:02 PM
jrrhd73must
10-02-2015 09:17 PM
Drastang
09-30-2015 03:48 AM
Quick Reply: Trunk Retainer nut fix
