Shelby Hood Pin Instructions
Guys, I got a set of Shelby Hood Pins for the car, for Xmas, just opened them, and no templates or instructions, what the hell? Anyone know where I can get what I need for a clean and proper install? Much appreciated!
remove the radiator cover and the plates go attached to the radiator support brackets. you'll figure it out when you see it... put some mustard, peanut butter, etc... on top of the pin then close the hood to leave a dot where you drill the holes... drill and your done... use the search function. they're are lots of hood pin install threads. good luck
location before opening it up with the proper size bit.
And use 118 degree metal bits instead of the aluminum
eating 135 degree wood bit.
A step drill is your friend on thin aluminum.
Follow this thread to post number 58 for instructions.....
http://forums.bradbarnett.net/showth...od+pins&page=3
jwog666
12-27-2021 08:09 PM
GT350 S550 Tech
09-29-2015 03:29 PM
mungodrums
09-28-2015 10:54 PM
3m, 9904, car, ford, hood, install, instrucions, instruction, instructions, location, mustang, pin, pins, racing, shelby
