you should buy the guys gloss black blackout that he said was 40$ haha it looked good on his car.... and it is easy peel and stick, i want to buy one soon but i have stripes and it might look,.. idk off?
That was the problem. Alcohol has highly evaporative properties causing the vinyl to stick quickly. Use soap/water mix and you can slide the vinyl into place easily and also, as mentioned, work out the air bubbles while it's wet.
Yep, a friend of mine owns a graphics vinyl shop and he recommends the soap/water mix too.
I still need to pick up a vinyl blackout.. I think matte will look best. I like the way it looks now, just the magnetic one isn't holding up. How durable is vinyl and will there be issues if I need to remove it in the future?
