Great CAM selections finally available
#22
RE: Great CAM selections finally available
ORIGINAL: lostsoul
wow.. all most 900 bucks!!..
Rex
#23
ORIGINAL: Andrew_06_GT
thanks for the info, but what exactly are the LOWER gears compcams recommends on the catalog page????
#24
ORIGINAL: chevykiller
Minimum 3.73 in autos and 4.10 in manuals. (4.10's accross the board for the aggressive) The other thing to note is the STALL recommendations for the autos. Will require an aftermarket torque converter also if you have an auto and the stall is single most important thing for auto guys.
#25
Don't know about anyone else, but I got a real kick out of the description for the #127100 "....Great low & mid range torque for towing applications".. I guess now you can hook up the boat or trailer to the GT and pull with ease!
#26
Maybe for the truck engine?
Our engines seems to pull well to 6000+ rpm now. Sounds like the first two cams might be less agressive than our factory cam with the rpm range they list.
ORIGINAL: PullMeOverRed05
#27
#28
Does anyone know the specs for our stock cams? Lift, Duration, etc...
I can plug it into Desktop Dyno and get a rough feel for what these cams are going to do...
Thanks,
Skrappy
Thanks,
Skrappy
Luke9222
10-22-2015 11:55 PM
