Sponsored by:
Sponsored by:
Mud in da tires?
Old 08-01-2006, 03:19 PM
clearym
clearym's Avatar
Default Mud in da tires?
Hey all,
I just read an article in the paper about people now putting Nitrogen in their tires to increase gas milage. Can anybody validate this? Does it have any performance detriments?
I've heard of "mud in da tyres" but not nitro.
thanks
clearym is offline
Old 08-01-2006, 03:26 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Default RE: Mud in da tires?
ORIGINAL: clearym
Hey all,
thanks
Nitrogen will NOT increase any type of performance including MPG. What it does is it keeps excess moisture from being introduced to your tire internally. Many installers are now using Nitrogen when they put new tires on because nitrogen displaces oxygen and water. Less H2O in your tire means less likely to 1) degrade the tire over time and 2) less likely to throw the tire out of balance since water does accumulate over time in a tire (when you add air).
Derf00 is offline
Old 08-01-2006, 05:06 PM
28HopUp
MF Administrator
28HopUp's Avatar
I believe all Godyear tires on NASCAR tracks are filled with nitrogen (well, maybe not the pace car!)
28HopUp is offline
Old 08-01-2006, 05:20 PM
6xStang
6xStang's Avatar
I believe that nitrogen will not expand and contract as much with temperature so that you get more consistent performance....but I defer to the chemists. Also, then that raises the question of whether you put 32 psi of nitrogen in a tire spec'd for 32 psi cold, or if you put 36 psi in expectation of air being +4 psi when hot.....but nitroben pressure staying steady.
I guess a google search is in order, but I leave that to others...
6xStang is offline
Old 08-01-2006, 05:29 PM
Black GT
Black GT's Avatar
Here is a news article about it.
Black GT is offline
Old 08-01-2006, 05:50 PM
demarcom
demarcom's Avatar
Not as prone to leach from the tire like regular air so your pressure stays more consistant. Bigger modecules I think... really
demarcom is offline
jwog666
12-27-2021 08:09 PM
CS2007
06-25-2019 09:45 PM
KingRando
10-02-2015 08:06 AM
marc954
09-29-2015 11:18 AM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
Quick Reply: Mud in da tires?
