07 Plenum Cover Questions
Old Sep 13, 2006 | 10:56 PM
Saleen05797's Avatar
Saleen05797
Default 07 Plenum Cover Questions
Hey guys,
Sorry for posting another thread about this but I still am not 100% sure on this after reading the topics. I have an 05 base Saleen and I just got the cover in last night. I want to get it installed but I guess I have to change out some of the bolts? What exactly is it that I need and how do I install it. I didn't get any instructions or bolts or anything else just the cover itself. Any help is appreciated!
Thanks!
Old Sep 14, 2006 | 04:56 AM
rex7010's Avatar
rex7010
Default RE: 07 Plenum Cover Questions
You need two bolts and two nuts.. the rear gets held down by clips ( you will see when you do it )
sorry no numbers on the bolts/ ask Ken at www.fordparts.com (send a e-mail after going to site )
he will HOOK you up.. he did me on the 1rst try..
it looks good btw..
Rex
Old Sep 14, 2006 | 10:10 AM
tmcmulli's Avatar
tmcmulli
ORIGINAL: Saleen05797
Hey guys,
Thanks!
Found my instructions, there's no copyright, so here you go! I drive an '05, but I can't imagine it changed much... took me a whole 5 min to do...and I'm a pretty lousy mechanic...
[IMG]local://upfiles/41012/062B69448F8148E095E710796DF727B3.jpg[/IMG]
[IMG]local://upfiles/41012/BDF1FDB332364E078E04D971986DE883.jpg[/IMG]
Old Sep 14, 2006 | 05:40 PM
Saleen05797
Thanks guys! I'll post some pics when I get it installed. It looks like the best engine cover imo, besides the Saleen supercharger which hopefully I'll be getting soon.
Old Sep 14, 2006 | 05:47 PM
mlcrycc's Avatar
mlcrycc
Saleen,
Did you get the Ford cover, or the Midwest Auto cover. I think the two are being confused here......
Mike
Old Sep 14, 2006 | 09:08 PM
Saleen05797
I got the Ford cover. But I think I just pop off those tabs/clips that hold down whatever line it is, put the cover over the stud and then cap the stud again. And I'm guessing the new bolts/nuts are for where the intake manifold connects to the throttle body if I remember correctly...
Old Sep 15, 2006 | 10:06 AM
bodyputtyless's Avatar
bodyputtyless
I ordered the bolt kit that everyone was saying you needed to add the cover to my 06. I found that the studs were in correct. I took a 1/4 inch drill bit and reemed out the two front neck washers that are incorporated in the rubber grommets. Then used the oringinal studs. Worked perfectly. The rear section is held down by the nuts atop the studs that hold the injector rail. The Midwest cover requires nothing more then bolt loosening and then retightening. I own both covers.
Tivo304
Aug 28, 2023 12:19 PM
GimpyHSHS
Sep 18, 2015 12:27 PM
04stangman
Sep 17, 2015 01:45 PM
aleit2013
Sep 4, 2015 11:58 AM
