Sponsored by:
Sponsored by:
Bolts with UDP
Old 02-01-2007, 07:50 AM
STANMAN
STANMAN's Avatar
Default Bolts with UDP
Just bought some Granatelli's from Lethal and recieved them today. No bolts. Are there supposed to be new bolts included??
STANMAN is offline
Old 02-01-2007, 10:15 AM
CrazyAl
CrazyAl's Avatar
Default RE: Bolts with UDP
Some kits include the bolts, and some don't. But the bolts aren't required.
There are two bolts that are commonly included.
One of them is the "install" bolt which is used to press the crank pulley onto the snout of the crankshaft. This bolt looks just like your existing crank bolt, but it's a little longer. If you weren't given this bolt, don't fret. Just go to your local autoparts store and borrow a harmonic balancer installer. Use that instead. It is actually a preferable way of installation anyway. You re-use your OEM bolt to actually secure the new pulley.
The other bolt that may be included is a bolt that is used to replace a certain stud on the alternator. The OEM stud sticks out pretty far and gets very close to the belt on the water pump pulley. Some kits give you a bolt that you can use to replace this stud. I personally prefer to simply cut off the protruding end of the stud. It takes about 20 seconds with a dremel tool or an air grinder with a cutoff disc. You could also do it with a hacksaw.
CrazyAl is offline
GimpyHSHS
19
12-19-2023 01:12 PM
baddog671
07-26-2016 01:20 PM
2poor4u2
09-26-2015 11:08 AM
maestro1024
09-21-2015 02:40 PM
trashxtrash
09-20-2015 10:49 PM
Quick Reply: Bolts with UDP
