Sponsored by:
Sponsored by:
Antenna Base Removal
Old 02-24-2007, 04:55 PM
BeeStang
BeeStang's Avatar
Default Antenna Base Removal
Has anyone attempted to remove and paint the antenna base (black trim)? I was just wondering if there are any concerns I need to know about before I attempt this. I just dont want to start wrenching on the top side of the antenna and run the risk of it falling into the fender area and not being able to get to it if it falls down into the fender. I did a visual and not much access to the area from behind the wheel well inside the engine compartment. The reason I want to do this is primarily for the same reason some of you are painting your mirrors, want it to blend in with the body. I also plan on painting my windsheild washer nozzels as well. That won't be as difficult as I know already how to remove them.
BeeStang is offline
Old 02-24-2007, 07:07 PM
BeeStang
BeeStang's Avatar
Default RE: Antenna Base Removal
Bumpage [8D]
BeeStang is offline
Old 02-24-2007, 07:14 PM
maniacmikey
maniacmikey's Avatar
It looks like the one I had on my f-150 if it is the same style it has a plastic cap that snaps on and off. Under the cap are 2 or 3 screws that hold the base to the fender. I used a butter knife to pry the cap off to get to the screws that had come loose. Be careful when prying the cap off cause it is easy to damage.
maniacmikey is offline
Old 02-24-2007, 08:52 PM
fairlane292
fairlane292's Avatar
ORIGINAL: maniacmikey
The base is so big that I don't know if painting it white is a good thing, gonna be weird (and big) if color keyed. ...anyway, the three screws under the cap are torx (I think they were 20's, not sure now) They appeared to be LokTite'd in though. ...hard to imagine them being loose because they arerather tough to get out w/o rounding them off. Get a brand new torx head adapter (Craftsman); put it on a 1/4 socket/ratchet; press down firmly but not "killer" so as to dent your fender, and gradually apply pressure. ...good luck man!
[IMG]local://upfiles/24316/4BDF5738723D4CEF8EE54A682D74D341.jpg[/IMG]
fairlane292 is offline
Old 02-24-2007, 08:58 PM
maniacmikey
ORIGINAL: fairlane292
Yea the being loose was on my F150 after 7 years of being run through the carwash.
Old 02-25-2007, 03:19 PM
BeeStang
BeeStang's Avatar
Thanks guys, I really appreciate the help.
BeeStang is offline
Old 02-25-2007, 10:42 PM
Menace
Menace's Avatar
The piece is connected to the antenna wire, and the only disconnect point is under the passenger seat; right before it connects to the head unit. It's kinda disappointing. I damaged mine by trying to use one of those "screw outs" I broke my antenna off and yeah... just one big mess. I'd like to take it off completely, and get the hole filled/painted.
Menace is offline
Old 02-26-2007, 12:06 AM
odiaz
odiaz's Avatar
I got rid of the antenna also. It was just too big and ugly. I went with the Metra amplified interior antenna that mounts on the windshield. Here's some instructions on how to do it.
http://www.cherod.com/mustang/HowTo/...a%20Delete.htm
odiaz is offline
Old 02-26-2007, 07:57 AM
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
Thanks
mygt500 is offline
Old 02-26-2007, 12:16 PM
wthalliii
wthalliii's Avatar
ORIGINAL: odiaz
Train 'em while they're young! She's going to be a great wife for some lucky man! Great picture and a cute kid.
wthalliii is offline
kevsgt
10-09-2015 10:12 PM
b8checker
10-08-2015 12:55 PM
Dathan
10-05-2015 05:52 AM
jrrhd73must
10-02-2015 09:17 PM
Florida Regional Chapter
09-30-2015 08:04 PM
Quick Reply: Antenna Base Removal
