Problem filling up
That's pure insanity!!!!!!
ORIGINAL: maniacmikey
I live in Oregon we are not allowed to fill our own cars. So I sit in the car and listen to the stereo and Goober has to deal with the pump.
This is one TSB that I wouldn't be so quick to jump on the TSB bandwagon with. Every trip to the dealer is a potentially new scratch.
ORIGINAL: mystang04
I've had this problem quite frequently. I just hold the nozzle upside down. Now I see so many have this problem. I'll be stopping at the dealer to have it fixed now that I know. Thanks.
ORIGINAL: tientran
Yesterday I checked my car. It was made on MAR 2005. That means it is qualified to have a new gas tank replacement. It will shut off if it is at 6 o'clock position, but, it is always OK to fill if I put the nozzle in 3 o'clock position . I don't know what to do? Take it to the dealer to have a new gas tank or live with it by using 3 o'clock position to fill gas.
ORIGINAL: Goody625
Its a common problem. Fords suggestion to me was use a different pump or turn the fuel nozzle upside down. Here is the TSB on it: Hope this works!!
Good Luck
http://www.allfordmustangs.com/forum...sb06_03_13.pdf
Good Luck
So far I have only filled up twice since I bought the car. First time no problem. Second time I had issues. I had to stop....pull up to another pump and try again. A guy behind me in a Corvette was just staring at me....like WTH!
Thanks for the advice. I don't know if I want to bother taking it to the dealer for something that only happens 4 times in six months, but its good to know in case the problem gets worse. Holding it sideways once in a while won't be too bad.
Whats up with the no pumping yourself in Oregon and New Jersey??? Thats just nuts! Can you go inside and grab a big glup or do you have to hit a drive thru for that? Nothing like having big brother tell you how to do everything.
OK, I filled up last night for the 3rd time since I bought the car. This is what my experiences have been so far;
1st time....purchased from Costco.....no problems
2nd time.....purchased from Sam's Club.....had problems.
3rd time.....purchased from Costco again with no problems.
I honestly think it depends on where you purchase gas from. Needless to say, I will be purchasing gas from Costco from now on! They are waaaay cheaper than Sam's Club anyway!
I filled up my car today for the first time since i got my new gas tank.....NO PROBLEMS. if your under warranty......get a replacement.....bc im sorry but 'holding it at the 3 o'clock position' IS BULLSH!T!!! Its a new car...u should be able to put gas in it. have them replace it.
jessicarabbit
Sep 25, 2015 12:41 PM
Sep 10, 2015 08:39 PM
