Shifting problems
Old Apr 19, 2007 | 09:42 PM
  #21
TacoBill's Avatar
TacoBill
Default RE: Shifting problems
Couple tricks I used to use (pre-MGW that is) is what's already been mentioned..
The 'release the clutch, then re-engage the clutch' method and the 4th to R jump.
Old Apr 19, 2007 | 09:43 PM
  #22
ClayBonics's Avatar
ClayBonics
Hope this helps you.
Here is a previous post I found I remember reading before:
https://mustangforums.com/m_2429020/tm.htm
StartMeUp- +1 to howarmat. There is a safety interlock in the tranny (at least the GT's manual) that prevents accidentally engaging reverse. I remember reading about it my the owner's manual. If memory serves, you can go from 1st or 2nd to reverse but not 3rd, 4th or 5th to reverse.
Old Apr 19, 2007 | 11:34 PM
  #23
randybobr's Avatar
randybobr
Thanks for all the help.
Old Apr 20, 2007 | 05:58 AM
  #24
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
That is normal from what I have been told and it happens to many people. Try placing in fifth first and then move down to Reverse. Works for me when acting up. Sometimes just move up a little in first than go to neutral and then proceed to reverse and that helps as well!
Old Apr 20, 2007 | 07:20 AM
  #25
05Stang4Me's Avatar
05Stang4Me
+1 on moving a little forward in first then reverse. This happens to me every once and a while. All I do is move forward just a bit and then the syncro gods are in line and off I go. Give that a try it will help.
ChampInSD
Oct 2, 2015 04:55 AM
Brandonfilipponi@yahoo.com
Sep 12, 2015 11:39 AM
Mustangmalo
Sep 6, 2015 05:22 PM
5.0 kevo
Sep 3, 2015 06:24 PM
