Hardwire radar detector
Old May 13, 2007 | 12:24 PM
  #31
05SDI's Avatar
05SDI
Default RE: Hardwire radar detector
ORIGINAL: JaysFreaky
What's the point of knowing if you've been hit with laser? Once you're hit, you're a goner anyway. *shrug*
Good question, but not entirely accurate!
http://www.escortradar.com/zr3.htm
http://www.pricegrabber.com/search_g...sterid=3718822
These ZR3 wereclose to$700 4 years ago! And YES its one of the few itemsthat actually works against laser! Feel free to do some research and read reviews! (and not from Escorts site)How bad do you feel you need to protect yourself?
Old May 13, 2007 | 12:28 PM
  #32
norvokov's Avatar
norvokov
That's not quite accurate about being screwed if you're hit by laser. I have a Valentine 1, and I've been warned so many times to slow down after a laser incident because the cop was scanning someone in front of me, and the laser beams bounced off them and hit the valentine 1. It happens all the time. Now, if I were the first to be scanned, I would be screwed, but half the battle is knowing where they are using laser. Usually a motor cycle cop under an overpass downtown in a city.
Old May 13, 2007 | 03:57 PM
  #33
User 113021's Avatar
User 113021
Interesting... I'll have to look into those laser jammers...
So where can I get one of those fuse tappers at? I'd just like to plug-in to an open fuse slot in my passenger kick panel.
Old May 14, 2007 | 06:12 AM
  #34
5pointslow91's Avatar
5pointslow91
I have an Escort 8500 X50.
I have 1 of those, i love that detector, saved me from many tickets except 1, when i was doing 40 over and got arrested for aggrivating speeding lol, its the 2nd best on the market, number 1 being the Valentine 1
Old May 14, 2007 | 06:15 AM
  #35
5pointslow91
Dont waste your money, jammers dont work at all.
Old May 14, 2007 | 11:15 AM
  #36
Joolander's Avatar
Joolander
Lord High Protector
What ever happened to the radar detectors with the receivers on the front & rear bumpers, and the display in the cockpit?
Old May 14, 2007 | 11:53 AM
  #37
Justin_R's Avatar
Justin_R
Not true.
ORIGINAL: 5pointslow91
Old May 14, 2007 | 12:05 PM
  #38
05SDI's Avatar
05SDI
Absolutely NOT true!
The ZR3 is one of the few that are proven to work.........
Old May 14, 2007 | 12:16 PM
  #39
EskimoPie's Avatar
EskimoPie
This needs to be qualified... RADAR jammers don't work at all... LASER jammers can be very effective... This is basically beacause radar frequencys are goverened by the FCC who are EXTREMELY strict about what can and can't be transmitted legally. I'm sure you've all seen the lables attached to most consumer electronics devices that says they 'can not cause any intereference with other devices and must accept all interference from other devices'. Lasers however are controlled by the FDA who don't force near as many rules as the FCC. Most laser jammers (or 'shifters') need to have the emitters mounted on or near the license plates to be fully effective however. This makes installations expensive.
Old May 14, 2007 | 02:30 PM
  #40
DocVenture's Avatar
DocVenture
http://www.rvparts.com/index.php?ua=...amp;searchtext=
Here's the link if you want to order a fuse tapper, but you local parts store should have them
