need tire help!
Old May 15, 2007 | 12:31 PM
LesteR723's Avatar
LesteR723
Default need tire help!
i got the 17X9 takeoff bullitts thats i'm wanting to put tires on. What size should i get? i was reccomended by a guy at tire rack to get 255/50/17's but i want something low profile that will fit.
i also want a tire thats gonna have great grip in wet and dry, as well as have a stable sidewall in the corners and be able to hold well in the corners.
which should i get? my favorite tire is the BFGoodrich G-Force KDWS2 but i'v been told that won't fit on my car. If it will let me know! if not, which of these should i get:
-Bridgestone Potenza RE750
-Nitto NT555
-Nitto Invo
Thanks!
Old May 15, 2007 | 12:52 PM
waykooljr's Avatar
waykooljr
Default RE: need tire help!
That's a good recommendation from the tire rack guy. A source I use for checking tire sizes recommends staying within 3% of the original tire size.
I have Nitto 555's on my car, they are holding up well and havegood wet and dry traction.
Old May 16, 2007 | 12:35 AM
LesteR723's Avatar
LesteR723
bump?
Old May 17, 2007 | 11:55 AM
LesteR723's Avatar
LesteR723
bump
Old May 17, 2007 | 12:08 PM
28HopUp's Avatar
28HopUp
MF Administrator
ORIGINAL: LesteR723
I am 99% positive that TAKE-OFF Bullitt wheels from Ford are 17x8", not 17x9". I point that out because the 1" difference may affect your tire choice. I bought 17x9" replica Bullits for my DR's, which are a close match to the stock Bullitts, but not an exact match.
ORIGINAL: LesteR723
The 255/50-17 tires should fit nicely on stock Bullitts. I believe their overall diameter is close to the 27" tires that come stock (so no affect on the speedo).
Old May 17, 2007 | 12:23 PM
StantheMan's Avatar
StantheMan
You could probably fit a 275/40-17, which would give you a low profile, that you are looking for, the only problem would be that you are slightly outside of the 5% tolerance. I personally went with 275/50-17 on the rear, the stock rim width is 1/2 inch per side smaller than recommended, but for me it has worked just fine, also the height is within 1 1/2% of stock.. I left the stock 235/55-17's on the front whcih gives a nice effect. A nice median would be the BFG's 255/50-17's all the way around with height a width both being within specs.
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
KingRando
Oct 2, 2015 08:06 AM
marc954
Sep 29, 2015 11:18 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
