Finding the 4-digit calibration code...
Old Jul 1, 2007 | 01:48 AM
Marks07GT's Avatar
Marks07GT
Default Finding the 4-digit calibration code...
Evening all - I'm looking to join the "CAI and Tune" club. However, when I go to submit my B A M A request, it asks for two bits of info I don't have.
First - the 4 digit calibration code. Per the SCT site, this is somewhere near the "passenger side of engine near front of motor.”, but I don’t know what I’m looking for. Is it stamped on the motor, on the shock mounts, or other?
Second question… how do I find the axle codeor gear ratio? This is a 2007 GT manual.
Any assistance appreciated. I'm axious to my order in and get roaring down the road a little quicker!
Thx
Old Jul 1, 2007 | 02:12 AM
Mikes_BLK_GT's Avatar
Mikes_BLK_GT
Default RE: Finding the 4-digit calibration code...
Passenger side small metal looking box on the side of your fuse box should be a sticker that has a 4 digit code which will be 3 letters and a number. Yours is an 07 so unless you paid for the 3.55 gearupgrade your running 3.31's, the axle code is on a sticker in the driver side door jam(atleast on my 06 it is). Another way to tell your gear ratio is a sticker under the car on the rear end.
http://www.brenspeed.com/tech/cpucode.html
Old Jul 1, 2007 | 02:13 AM
hammeron's Avatar
hammeron
i'm too slow...must be slippin'
Old Jul 1, 2007 | 10:35 AM
Marks07GT's Avatar
Marks07GT
Thanks Mike... perfect.
Quick question for you... I notices in your sig that you have an AirRaid CAI and use Brenspeed. Do you run with the restrictive insert in or out now that you have your tune? I originally thought that the idea was you leave it in if no tune, but to remove if you are tuning. However, the email note I got from Doug at B A M A indicated that, based on his dyno tests, it loses 3-4rwhp if removed, and makes driveability worse.
Curious... and thanks again for the help on the axle and codes. Got 'em both this morning.
Old Jul 1, 2007 | 01:43 PM
Mikes_BLK_GT
ORIGINAL: Marks07GT
With Brents tune I have not experienced that atleast not that I know of. I pulled the restrictor when I loaded the tune, driveability is wayyy better than the stock tune w/retrictor installedIMO but I havnt tried Brents tune w/restrictor. I already had the airaid and Brent could have easliy talked me into another CAI but instead talked me into just tuning this one. If I werent planning on going FI I would try B.ama and VMP as well and maybe even a different CAI.
Old Jul 1, 2007 | 05:20 PM
s197richie's Avatar
s197richie
I ♥ Acer
ORIGINAL: Marks07GT
by restrictor are you guys talking about the hydrocarbon filter in the stock intake, because everything I read says that those were discontinued sometime in the 05 model year and the newer stangs don't have one...or are you talking about something else?
Old Jul 1, 2007 | 07:45 PM
Mikes_BLK_GT
ORIGINAL: s197richie
ORIGINAL: Marks07GT
No, were talking about the MVT(modular venturi technology) restrictor in the airaid cai.. With it in you can run the airaid w/o a tune, but when tuned you(can) pull it as I did, giving you a 100mm intake tube. Basically all it is is a smaller tube inside the front part of the larger intake tube.
lincolnshibuya
Dec 8, 2015 04:37 PM
jerrytubes
Oct 23, 2015 12:11 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
guitarman376
Sep 30, 2015 05:54 PM
Sixer4Life
Sep 29, 2015 07:03 PM
