Question on Fuel Pump TSB
Mike,
Post on here if you do take it in & your results. I've had the same issue a few times,maybe about 6-8 times in the past year. I do cruise 24m each way to work with mine, usually have the cruise control on. Punch it off & coast up the off ramp.Have had it stumble when pulling out @ the stop sign, seems to depend on how you accelerate;easy or hard, no issue;if I pull out moderatly aggressive it will sometimes stumble. Has not been an often occurance,so I haven't dealt with it yet. I pretty sure if I take the CAI off, reflash & take it in, it will be one of those'Can't duplicate problem'. I just don't have the time usually to waste an afternoon @ the dealer. My local dealer is NOT mod-friendly. If it gets any more frequent, I'll for sure take it in, but I'm also weighing the option of upgrading the pump myself. Alot less hassle & time on my end.
When I went in & talked with the service manager about it,I got the 'never heard of that TSB before'. Showed him the printout I had & his response was 'where did you get this?'
Larry
Larry
ORIGINAL: aircare84
Mike,
Larry
Mike,
Larry
, I don't think it would take more than an hour or two, and, any excuse to take a day off work to mess with the car is a good day.....[8D]Mike
I see most of you guys have manuals.....do any of you know if this problem is prevalent in the automatics also? and im assuming you mean that when you press the gas, it takes a second for the car to go off, almost as if its tired, and is takin a deep breath before it starts to go again. Sorry for the analogy, thats just how ive always thought of it,and if so, ill be needing to take another trip to the dealer......
Took my 06 Roush with KenneBell supercharger in and they didn't give me any trouble. Yeah, Boost-A-Pump connected and all. The first pump they put in worked fine, but the fuel sender crapped out so they put another one in.
Paul
Paul
ORIGINAL: Zrz11386
Mike
