rim paint
Old Sep 28, 2007 | 09:48 PM
Jsierzega's Avatar
Jsierzega
Default rim paint
i have the 17 inch bullits and was woundering were i can buy rim paint to paint them black?
Old Sep 28, 2007 | 09:52 PM
Dennis074.0's Avatar
Dennis074.0
Default RE: rim paint
I'd bring them to a body shop and have them paint it.
You can also buy duplicolors wheel paint at any auto parts store. You will also have to sand it down REALLY good, then clean it really good, sand it some more, then clean it again and make sure all dirt and dust is off. then paint it, and probably put a clear coat, or protective paint over it.
I'm not 100% sure though, maybe someone else can add on to that.
Old Sep 28, 2007 | 10:29 PM
Thurman's Avatar
Thurman
Don't do it man! You are about to f them up.....
Old Sep 28, 2007 | 10:49 PM
Eleanor06's Avatar
Eleanor06
Duplicolor-Go by their directions ! But I have also used engine paint too !
Just clean the wheels in dawn to remove grease,wax..etc. Then wipe them with alcohol(very important)After that
rough up the surface with 1500grit sand paper for tooth for the paint.Wash,rinse,and wipe with alcohol again,then use
a tack cloth to pick up small particles of dust and gritthen paint!
Old Sep 28, 2007 | 11:07 PM
jeffsmachine's Avatar
jeffsmachine
BMW Dealership parts dept's sell wheel paint in spray cans.It is some fancy stuff from germany and is highly durable.I beleive they only have silver and clear.Just buy the clearcoat.Then You can get a good flat black in a spray canlike "krylon industrial toughcoat" at home depot or whatever.The flat black will make for easier sanding before you clear it. Practice on scrap metal first to get the hang of it.
If You cant find the BMW clear,Griot's Garage sells wheel clear that is good too.
Also get good quality masking tape from a body shop supply store- it will give You a nice sharp paint edge.
jeff
Old Sep 28, 2007 | 11:46 PM
v6VenoM's Avatar
v6VenoM
I have the premium wheels on my GT and I painted them black. Buy brake cleaner, wash them off with a hose and then use the brake cleaner. I used 400grit sand paper and sanded them down good, making sure there is no shiny part of the rim left. Then I put 3 coats of primer on, 3 coats of black and 3 coats of clear coat. I thought my rims came out excellent. All in all I spent $50 on materials.
http://s39.photobucket.com/albums/e1...nt=Rims005.jpg
http://s39.photobucket.com/albums/e1...nt=Rims001.jpg
http://s39.photobucket.com/albums/e1...nt=Rims003.jpg
Old Sep 28, 2007 | 11:51 PM
Eleanor06's Avatar
Eleanor06
v6VenoM-The wheels look great black,but in your second pic is it just the pic or
do you have a little orange peel in the clear?Just asking cause incase it is,I can help you out to remove it..
Old Sep 29, 2007 | 09:29 AM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: Thurman
If these are your primary and only wheels I would say
have it professionally done but for that price you can
pic up a set of factory OEM black bullitts for the same
price on eBay as getting them done professionally.
Or the rattle can paint on ?perfectly good but just the
wrong color? rims is just too much work for minimal
return. IMHO
Check the bay for rims first.
Explore all options besides the 'paint it yourself on
the weekend in the garage' approach.
Old Sep 29, 2007 | 06:45 PM
fairlane292's Avatar
fairlane292
ORIGINAL: Thurman
Agree, save a bit more $$ and buy another set of rims. If you do decide to paintthem they need to be done in a shop in base black and clear. ...that is if you want a durable finish. ...you can clean them and sand with 320 wet if you want to save $$. ...you really don't want to pay $75 an hour for cleaning and sanding them do you?
As far as cleaning, make sure you clean every bit of the rim (backside too) Clean the face twice with a detergent like Dawn. Unless you ran into some grease somewhere that's all you need to remove the dirt, brake dust, etc. Most brake cleaners will eat clear coat, no need to use that. The shop will clean before priming as well. When you wet sand, have a riny bit of Dawn in the water. But my first recommendation is "don't paint them".
guitarman376
Oct 11, 2015 01:47 AM
Oct 1, 2015 09:29 AM
mungodrums
Sep 28, 2015 10:54 PM
GLOCKer
Sep 28, 2015 07:36 AM
mustangchef
Sep 4, 2015 08:08 PM
