Mods and Problems
Old Oct 2, 2007 | 06:59 PM
  #21
howarmat's Avatar
howarmat
s197 Junkie
Default RE: Mods and Problems
You have the panhard installed backwards then.....the elbow goes on the other side...........
Old Oct 2, 2007 | 07:07 PM
  #22
thewarmachine's Avatar
thewarmachine
ORIGINAL: thewarmachine
The Panhard rod should have included two elbow grease fittings instead of one elbow and one straight. It doesn't matter which way the rod is oriented, that straight fitting it going to be difficult or impossible to get the grease gun on.
Old Oct 2, 2007 | 07:08 PM
  #23
moosestang's Avatar
moosestang
14. The whole concept of the Panhard rod and it's lack of symmetry just blows my mind with it's retardedness. You'd think a simpler and better idea would have been used all these years (the Watts linkage is only slightly more satisfying) than to put some diagonal rod from one end of the frame to the other.
There is, it's called a triangular 4 link, but it isn't perfect either. I believe the last generation mustangs used this setup. They have two upper diagonal links that center the rear axle.
Old Oct 2, 2007 | 07:09 PM
  #24
moosestang's Avatar
moosestang
ORIGINAL: howarmat
+1 I don't see the problem here.
Old Oct 2, 2007 | 07:10 PM
  #25
howarmat's Avatar
howarmat
s197 Junkie
you will be able to get to the fittings if you switch......you say its GOING to be hard.....have you even tried?? Themetal stop really is not in the way...
Old Oct 2, 2007 | 07:20 PM
  #26
thewarmachine
I give up. Maybe it will work. The point is that there were no instructions and they should have used two elbow fittings.
Old Oct 2, 2007 | 07:21 PM
  #27
thewarmachine
I will reverse it if I decide to get gears. Otherwise, it will just have to stay half-greased.
Old Oct 2, 2007 | 08:46 PM
  #28
sleeper2's Avatar
sleeper2
Such is life in mod world. That's what is great about these forums. You can find what's tried and true.
Sleeper2
Old Oct 3, 2007 | 02:16 PM
  #29
TheRebel's Avatar
TheRebel
[align=left]
ORIGINAL: pascal
[/align]
Now, I get frustrated with computers because there'are too many things that I don't understand about themand sadly, never will. Although I'll never bust a knuckle playing with them (or will I?), I rather work on cars. Moddin' that is
Yes you will. Just wait till you need to pull the white connector (molex) out of a hard drive or CD-rom and its tight. Pull a little harder and it comes out and you bust you knuckles on the case. Plus the case metal is thin so it will cut you up like a razor blade.
Old Oct 3, 2007 | 02:26 PM
  #30
thewarmachine
Hmmmm....I can think of another way I might bust my knuckles on a computer ...........
Tivo304
Aug 28, 2023 12:19 PM
AMAlexLazarus
AmericanMuscle.com
21
Apr 4, 2020 02:16 PM
Luke9222
Sep 4, 2015 06:46 AM
5.0 kevo
Sep 3, 2015 06:24 PM
AMAlexLazarus
AmericanMuscle.com
Sep 2, 2015 08:59 AM
