dead battery.
Old Nov 24, 2007 | 08:08 PM
batmobile2005's Avatar
batmobile2005
Default RE: dead battery.
until you find the problem (if you do), put in a disconnect, works like a charm
Old Nov 24, 2007 | 09:48 PM
TPony's Avatar
TPony
If the search worked you would be able to see many posts on this topic...I had the same problem twice..got me a battery charger...charged it to 100%....have not had any issues like in one year...despite leaving the stang sit for many 21 day trips...
Old Nov 25, 2007 | 08:06 AM
2cokeman's Avatar
2cokeman
This condition is only with the shaker 1000 amp, not the 500
Old Nov 25, 2007 | 08:24 AM
2007Grabber's Avatar
2007Grabber
I have the base model single disk stereo that is running an aftermarket amp that IS connected correctly with the remote wire. When I power the car or stereo off, the amp turns off (it has a power light). I have been having problems with my battery since the weather has gotten cooler. If I let the car sit without running for more than 3 days, dead battery. The amp I have has been in 2 other cars anddid not causeany drain on their batteries. I am planning on investing in a Red Top as soon as I bring her out of storage in the Spring. My guess: Ford uses cheap batteries.
Old Nov 25, 2007 | 08:51 AM
Tri C's Avatar
Tri C
ORIGINAL: 2cokeman
No, it's not limited to the 1000.
The only way I've cured it is to turn my Shaker 500 off and NOT engage the active anti-theft system. Fortunately, it's in a garage.
Old Nov 25, 2007 | 10:14 AM
batmobile2005
ORIGINAL: 2cokeman
yeah, id believe you if it didnt happen to my shaker 500. its with both systems, to the extent of my knowledge
Old Nov 25, 2007 | 10:27 AM
Thurman's Avatar
Thurman
These car are notorious for dead batteries. Never happend to me yet. Their has been many threads on this. The best thing I cold tell you is, battery tender if sitting more than one week.
Thurman
Old Nov 25, 2007 | 12:31 PM
Jokeurmnd's Avatar
Jokeurmnd
yeah you got to turn the car on at least once a week or the battery dies, Just jump it for a bit and you should be good to go
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
Thunderball
15
Nov 22, 2015 11:49 PM
jessicarabbit
Sep 25, 2015 12:41 PM
8lug
Sep 21, 2015 01:33 PM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
