eletric problem..
Old Feb 6, 2008 | 10:19 PM
Rainson's Avatar
Rainson
Default eletric problem..
anyone saw this before?how to fix it?
Old Feb 6, 2008 | 10:23 PM
hammeron's Avatar
hammeron
Default RE: eletric problem..
i would check the ground wires, for
the non working lights.
kdrshocker's Avatar
kdrshocker
never saw it before - but it's the same with all electrical connectons. start at the bulb if it's good break out a voltmeter to see if there is power getting to it.. and just slowly work your way back along the wire.
Old Feb 6, 2008 | 10:26 PM
landon.moss's Avatar
landon.moss
damn that's a lot of lights .....agree completely though, check grounds....and any in-line fuses (which wouldn't count in this case cuz if there were any, both lights of each type would be out
[/align]
Old Feb 6, 2008 | 10:28 PM
boochy's Avatar
boochy
CSMG Moderator
You must be scared of the dark to have that many lights.
Old Feb 6, 2008 | 10:35 PM
landon.moss
i have that many lights on my mopar, but she's 38 years old and needs all of em with that old tech...has low beams, high beams (lows stay on), park lights, and road (fog) lamps...bout the same look you got, but the park lights are down my the plate...looks like an alternators worst night mare :P
[/align]
ShadyNinja's Avatar
ShadyNinja
here in IL you are only allowed 4 lights on the front (IIRC)
so you would be fine here
Old Feb 7, 2008 | 03:14 PM
157dB's Avatar
157dB
Cut & Paste Expert
Got out the good ol VOM and check for power at
the bulb connectors. Then check continuity of the
ground on the connector. Then check the bulbs for
continuity. Swap bulbs and if the problem follows,
its a burnt out bulb. If the problem stays, its the
wiring.
Old Feb 7, 2008 | 03:21 PM
justang07's Avatar
justang07
can you post some more pics of your car.
Old Feb 7, 2008 | 03:26 PM
GidyupGo's Avatar
GidyupGo
ORIGINAL: ShadyNinja
Same in Colorado.
jaiidutch
Sep 14, 2015 10:29 AM
luizGT91
Jun 3, 2007 06:54 PM
liketoskate1
Jun 2, 2006 05:38 AM
Jake89
Sep 12, 2005 08:15 PM
93yellowfeaturecar
Oct 21, 2004 12:17 AM
