Sponsored by:
Sponsored by:
06 gt s/c ???
Old 03-05-2008, 11:40 PM
SnakeBite03
SnakeBite03's Avatar
Default 06 gt s/c ???
whats the most rwhp you can get out of a stock supercharged motor... with a 5 speed 06 gt.??? with the motor being bone stock and putting a kenne bell on how much rwhp can i get out of it....
SnakeBite03 is offline
Old 03-06-2008, 12:37 AM
blike
blike's Avatar
Default RE: 06 gt s/c ???
Safely on stock internals? 450ish
blike is offline
Old 03-06-2008, 04:17 AM
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
1+ but no guarantees on that and many have been running higher numbers though....(tick,tock,tick,tock.....BOOM!)
(I am) but use the car more for show more than go!
mygt500 is offline
Old 03-06-2008, 07:39 AM
MustangGT0405
MustangGT0405's Avatar
ORIGINAL: mygt500
Honestly I dont think you are any worse off than if you had 450rwhp. The key is to get a nice safe street tune and get the most you can out of 10psi. Whatever that number is be happy.
I like to drive my car alot all over the state/country so I will only get 91 octane tunes. This is so if I go someplace I cant get 93 I am safe, and the fact different gas stations fuel is not created equal. So I run a few degree's less timing than I could, I like the safety factor.
Honestly I dont think anyone would really miss 15rwhp at this power level.
Good luck
MustangGT0405 is offline
Old 03-06-2008, 07:52 AM
zkiller
zkiller's Avatar
I am running 11 PSI on the stock engine.
My best trap speed was 120 MPH on a car/driver weight of 3950 so that calculates to 532.71 approximate RWHP with a HP calculator. I have not dynoed my current setup.
My car has 12,000 miles on it and sees about 50 1/4 mile track runs per year.
My motor has held together fine BUTI run 100 octane all the time.
zkiller is offline
Old 03-06-2008, 09:08 AM
brian06eleanor
brian06eleanor's Avatar
one of my good friends had his tuned by mph over a year ago and runs 10psi he made 481rwhp and 460rwtq and it has done fine for over a year. anything under 500rwhp will be fine with a good tune as long as you dont beat on you car all the time.
brian06eleanor is offline
Old 03-06-2008, 09:25 AM
RedStang06
RedStang06's Avatar
400 rwhp should be good enough for the average Joe.
RedStang06 is offline
Old 03-06-2008, 10:08 AM
exx1976
exx1976's Avatar
+1 on the 450-ish being a safe number, that certainly is the general consensus around here. I'm more than happy with the numbers I'm making, and like GT0405 said, no one would miss 15 hp at these levels anyway.
exx1976 is offline
Old 03-06-2008, 11:52 AM
06Saleen3V
06Saleen3V's Avatar
Our Whippled GT sits at 519rwhp on a stock motor and we drive the SH*T out of it (over 20K miles)...no boom yet, runs perfect
06Saleen3V is offline
Old 03-06-2008, 12:15 PM
MustangGT0405
ORIGINAL: 06Saleen3V
Ah, but you see you guys dont care if it blows, for that reason it never will. Motors only explode when you CARE if they do.
Case in point I had a friend that had the most beater 91 mustang GT you ever saw. We painted it flat black at his appartment complex. He ported the heads on his kitchen table with a dremel. Then he bought a used nitrous kit and ran a 125 shot. He got 39lb injectors at a swap meet but they only had 7, so he ran one cylinder with a 24lb injector. He sprayed nitrous all the time. The car ran perfect. Why did it work? Because he didnt care about it.
My luck I would grenade the engine if I looked at a nitrous kit.
Sorry wierd reference, but I believe in this thing called Murphy's Law.
Soldier GT
08-12-2015 03:46 PM
94Cbra
10-08-2004 07:00 AM
RollinThunder
09-16-2004 01:42 PM
iiiGTiii
08-26-2004 03:07 PM
RollinThunder
05-17-2004 01:06 AM
Quick Reply: 06 gt s/c ???
