Last edit by: IB Advertising
Browse all: Brakes
- Ford Mustang V6 1994 to 2004 How to Replace Brake Pads, Calipers, Rotors
Step by step instructions for do-it-yourself repairs.
Browse all: Brakes
brake caliper removal
anyone have a write up of know how to take off the calipers? i want to paint them but i have the spray and would rather not get yellow paint all over everything else. oh and one other thing, how do you bleed the brakes?
I sprayed mine too, theres only 2 bolts to removethe caliperfrom the spindle. You don't need to completely take them off, once you remove the calipers you can slip the rotor off, remove the outside brake pad (put one bolt back in to hold the caliper to spindle while you paint), tape off/cover anything you don't want sprayed. Mine dried really quick to touch, 10-15 minutes you can put it back on being careful.
Taco bill's rotor replacement details how to remove the calipers:
https://mustangforums.com/m_3083874/tm.htm
maestro1024
Sep 21, 2015 02:40 PM
Sep 8, 2015 11:50 AM
