HELP!!! - Air/Fuel Ratio Gauge
hey guys.. im finally trying to install this damn gauge.. and everything is/has been hooked up except the green wire that goes to the o2 sensor.. i am tapping the rear sensor, passenger side..
there are 4 wires..
-Green
-Blue
-Purple
-Black
after first tapping the green.. nothing happen when i started the car..
tapped the purple.. and then the guage went from permanently being in rish position.. it moved down to the lean position.. but nothing more..
tapped the blue.. same thing..
black.. nothing..
WTF!?!??!
IF YOU KNOW WHY OR WHAT WIRE TO TAP... PLEASE HELP!
there are 4 wires..
-Green
-Blue
-Purple
-Black
black.. nothing..
WTF!?!??!
RE: HELP!!! - Air/Fuel Ratio Gauge
well i have high flow cats.. and i ended up finding out that the black wire is the sending wire..
so i tapped it.. and its working.. but its not real sensative.. which would make sense, if i went to the upstream sensor.. it would polly work better.. but whatever.. atleast its doign SOMETHIGN now..
ORIGINAL: LX200
Huh? YOu using a wideband? If not, it will just jump from rich to lean. No real use.
how did it save you a motor?................ OHHH bc when you were rompin on it.. it went lean and you saw that so you let off im guesing?..
dunno.. but yes ppl .. i know these are worthless.. but i figured it would be better than anything else for the time being since im not near getting blown yet..
ORIGINAL: GTstangB.F.D.M.
Just don't use this kind of connection unless it's temperary.
jwog666
12-27-2021 08:09 PM
andrew1969
16
01-08-2016 02:48 PM
