Which direction would you head
Old Apr 18, 2008 | 08:52 PM
ravekennels's Avatar
ravekennels
Default Which direction would you head
I am planning on having a sc or turbo added next year. Right now it has an aftermarket catback and hurst shifter. What would your first mod be? Headers? H or X pipe? gears? Etc?
Old Apr 18, 2008 | 11:23 PM
06silvergt's Avatar
06silvergt
Default RE: Which direction would you head
Used C&L or JLT ($150)and a used XCal2 ($150 - $200 you should be able to delete it from your kit when you get a SC or Turbo), then gears. I wouldn't dump alot of money in headers/exhaust until you decide if you are going SC or Turbo. Nothing like dumping big $'s into LT's and x-pipe to decide you want to go Turbo and have to take a hit on all that stuff. If you decide to go turbo you can run UDP's and keep them. Just my random thoughts.
Old Apr 18, 2008 | 11:55 PM
rojizostang's Avatar
rojizostang
gears are going to give you the biggest rush, but you need to be careful about what size to install if you're definitely going to a power adder later on. I ran 4.10's in my oogt (n/a) for 5 years and still averaged around 20mpg with a 285/40/18 tire. s197's run a taller tire...you should be able to run a 4.10 even if you do go to a power adder. i'm probably going to stay n/a and will soon be installing 4.30's. even with the 4.30's and the stock 235/50/18 tire the car will be turning less rpm's than my oogt. JMHO
Old Apr 19, 2008 | 08:26 AM
jlaurens06gt's Avatar
jlaurens06gt
depends on what will you be using the car for: show, street, strip, auto-x?
there is a wide array of suspension mods that will allow u to plant that future power
grippy tires for same reason
one-piece ds to support big power
brake upgrade?
all depend on your application
lots of appearance mods......
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mustangheaven
Jan 3, 2016 11:20 AM
kevsgt
Oct 9, 2015 10:12 PM
mustangheaven
Oct 7, 2015 10:23 AM
Drastang
Sep 30, 2015 03:48 AM
