Lowering Questions
Old Jun 27, 2008 | 09:06 AM
doctorj77's Avatar
doctorj77
Default Lowering Questions
I've tried the search function and it appears to still be on the fritz. My question is, can you install the Eibach lowering springs "rear only" with out needing to re-align the rear axle?
I have the Roush rear springs in my 06 which lowered 1in and I had no problems. I'm considering getting a set of used Eibachs for my Dad's 06, but these drop supposedly 1.4in. Is that too much or would a adj panhard bar be required?
He's currently stock right now.
Old Jun 27, 2008 | 09:31 AM
157dB's Avatar
157dB
Cut & Paste Expert
Default RE: Lowering Questions
Maybe need an adjustable panhard.
If the rear end swings too far over
causing tire rub under full suspension
compression (up against the bump stops).
What size tires/rims/offset?
Old Jun 27, 2008 | 09:36 AM
Chris07GT's Avatar
Chris07GT
Should be fine. I have the Eibach pro-kit only, no springs or PHB.
Old Jun 27, 2008 | 09:41 AM
doctorj77's Avatar
doctorj77
Seems to me when you approach 1.75 - 2in is when it becomes a concern. He's using the GT stocker wheels and tires. He was impressed with the appearance when I lowered mine and he's been wanting to do the same.
The budget won't allow a PHB, so lets say for example the rear gets slightly thrown off, could a rear end alignment solve it?
Old Jun 27, 2008 | 09:47 AM
okbfd's Avatar
okbfd
I lowered the rear 1.5" with the Eibachs anddidn't haveany problems......but mine was mostly a garage queen and didn't have that many miles on it [8D]
Old Jun 27, 2008 | 10:43 AM
Argonaut's Avatar
Argonaut
ORIGINAL: doctorj77
This car does not have any "Rear Alignment"...there are no adjustment points in the stock rear (no Toe, Caster or Camber, no lateral adjustment for the stick axle). Like mentioned above, I also ran the Eibachs without an adjustable PHB for several months. The rear did shift slightly but it was barely noticable and did not cause any issues: handling, rubbing, etc.
YMMV - every car is a bit different, chances are you will have no issues - visual or techincal but...you never know until you try it.
Old Jun 27, 2008 | 11:27 AM
doctorj77's Avatar
doctorj77
ORIGINAL: Argonaut
ORIGINAL: doctorj77
Thanks for the update. I'll give it a try. Hopefully the springs are still for sale.
Tivo304
Aug 28, 2023 12:19 PM
04stangman
Sep 17, 2015 01:45 PM
EASTIDEE123
Sep 14, 2015 03:52 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
