i've searched this topic and cannot find a definite answer for my door lock issue
I recently had an issue with someone hitting my drivers side door on my 06 GT and leaving a small dent in my door. I took the door panel off to try and bump the dent out until i can get it repaired the right way. While i had my door panel off, it was sitting on my drivers seat while i bumped the dent out, but i accidentally put too much pressure on my door and the panel slid off, pulling on some of the wiring (i think) and causing my door lock to not function. I had to put the black plastic piece back onto the circut board. None of the wires were actually off or pulled away from the board, but i know that doesnt mean they arent possibly messed up. I noticed that it looks like a pin or something of that sort is missing from the actual plastic door lock device on the door panel.It will NOT lock with the fob or by pressing the lock button on either the drivers side nor the passenger side. Anyone know what i may have done?
Check Fuses as the SJB controls the lock
solenoid independent of the door switch.
http://iihs.net/fsm/?dir=40&viewfile...or%20Locks.pdf
You prob. pulled loose one of the pins. Re check them. It happens all the time. I work as a car audio installer, very easy fix. Find the pin that might be bent or is pulled out and push it back in. I doubt you blew the lock motor, but thats also a possibility.
The SJB fuse panel.
Its layed out where its located in the Owners Manual.
Passengers side kick panel. Pull the access panel to get to the fuses.
The fuse you want is outined in the Owners Manual.
http://www.motorcraftservice.com/pub.../07musog1e.pdf
CMcNam
10-30-2022 11:40 PM
