Aeroforce gauge dimming??
09-02-2008, 08:40 PM
Does anybody know if the Aeroforce gauges can be hooked up to the interior dimming switch?
09-02-2008, 08:51 PM
Dont know for sure but my ones did not. They do have 3 levels of brightness that you can select.
09-02-2008, 09:01 PM
Thats good to know about the brightness level, I was worried about how bright they would be at night.
09-03-2008, 12:54 AM
Multi-Tasking Moderator!
I am pretty sure you cant but I dont have mine yet so maybe someone else will give solid info for you and welcome to the forum!
09-03-2008, 07:39 AM
I really dont see how. Everything basically runs off the OBD port. Then you can run a power wire so that it only turns on when the car is on.
You can change brightness within the gauge though.
I have the blue text and I set it to the 2nd brightness setting and it works great for me day and night.
09-03-2008, 09:29 AM
Cut & Paste Expert
Here is where to hook it if it has an illumination lead.
09-03-2008, 01:45 PM
Retired Mod
it runs off the OBD port... cannot be controlled by the interior lighting
jwog666
12-27-2021 08:09 PM
Galactic
04-29-2019 02:56 PM
andrew1969
16
01-08-2016 02:48 PM
SteelerNation82
09-16-2015 07:11 AM
Pyrate Dave
09-10-2015 07:30 PM
adjust ,
aerofoce ,
aeroforce ,
aeroforve ,
brightness ,
dim ,
dimmer ,
dimming ,
gauge ,
gauges ,
mustang ,
rs3
