NON stock exhaust and rattles?
Old Sep 11, 2008 | 10:33 PM
JayFi's Avatar
JayFi
Originally Posted by avengence
My pypes violators rattle. Only on the side I was fiddling with. I tightened one side with a big impact wrench and the other side with a ratchet. The side with the ratchet rattles. I am going to do it again with the impact wrench. Mine only rattles at start up though so its not that noticable, my squeaking mirror is more annoying. I also have a small exaust leak on the clamp to that muffler that rattles.
+1 on checking the hanger bolts when it rattles. You would not believe the noise those washers can make if they aren't tight.
Old Sep 11, 2008 | 10:44 PM
rshamekh's Avatar
rshamekh
I had the exact same rattle you described
when I had the O/R H with my stingers.
I knew it was somewhere in the front,
probably where the H-pipe meets the collector.
Several months later, I put the stock H back
on for inspection, and the rattle is GONE!
So, it was probably bad fitment from Pypes,
or maybe bad installation by me.
I really miss the way the exhaust sounded
with the O/R H, I'm thinking of putting it
back on...
Old Sep 12, 2008 | 12:01 AM
shanec's Avatar
shanec
Installed my FRPP Stingers today. One rattles because the hanger elbow touches a bracket. I can wiggle the exhaust tip and duplicate the rattle. Pretty sure this is where it is coming from. Can't very well bend the elbow farther away. I think I can bend the bracket out of the way though.
Old Sep 12, 2008 | 12:27 AM
One Bad Stang's Avatar
One Bad Stang
i have a slight rattle when i hit the gas, say in 2nd gear at about 1500 rpm, but i think its just the deep sound resonating through the car.
Old Sep 12, 2008 | 07:47 PM
funtimesalways's Avatar
funtimesalways
i still have the nasty rattle with boomtubes, its a loud squeal at low speeds and random rattles at all rpm. im just going to take it to a different exhuast shop. i brought it back to the shop i had it welded at orginally, and they said "im sorry sir, we do not warrenty our work on 3rd party exhaust systems" ummm, ok, you cant put the thing on a hoist and inspect the hangers? geeze
Old Sep 12, 2008 | 07:53 PM
Roy_R's Avatar
Roy_R
So what happened here?
drfister
May 3, 2018 10:38 PM
Spiral534
Oct 6, 2015 04:31 PM
cbird1177711
Sep 2, 2015 08:51 PM
iculookin
Sep 2, 2015 12:34 PM
Itstbrown
Aug 9, 2015 03:49 AM
