LED Interior Lighting
Old Dec 24, 2008 | 02:16 PM
  #21
phatcat's Avatar
phatcat
I'm interested in the hardwire radar, I tried to do this but was unsuccessfull. Can you tell us how to do it or give us a link.
Old Dec 24, 2008 | 02:51 PM
  #22
Burnsy's Avatar
Burnsy
yeah? i used t taps how is that bad? What would you have done?
Solder and heat-shrink.
That's not exactly what I'd call a "hack" job. How is that a "nightmare" for a new owner?
It's 4 clips. I didn't use clips myself....I took an exacto blade and stripped some insulation off the wires, then soldered and taped. I'm sure it's much easier to undo clips than solder if you wanted to uninstall them. If I would've had the clips...I would've used them. Much easier and quicker to install. Besides if I ever sell her...I'm talking all my **** off.
No it doesn't work that way, you don't just "pull off" those wire taps. They will eventually fail, and will compromise the wire and can be dangerous.
Old Dec 24, 2008 | 04:39 PM
  #23
zporta's Avatar
zporta
here comes the negative posts again...
Old Dec 24, 2008 | 05:29 PM
  #24
EagleStroker's Avatar
EagleStroker
Was thinking the same thing. Is that really necessary, the fact of the matter is people do things differently it doesn't mean it's right or wrong. Geez.
Old Dec 24, 2008 | 11:18 PM
  #25
StangHarley's Avatar
StangHarley
Not to be negitive...however:
1) those connections WILL fail
2) if you have time to do it over, you've got time to do it right
3) solder and shrink tube
I really like the lighting. Good layout and effect.
Old Dec 25, 2008 | 12:18 AM
  #26
pinche_maniaco's Avatar
pinche_maniaco
Originally Posted by 157db
Oh yea, those Insulation Displacement Connectors looks like a
wiring nightmare for the next owner. What a hack job to a perfectly good
virgin OEM wiring harness. I would not be proud of that and be posting
pics to boot. Thats wiring like you might get at CircuitCity.
hater..
Old Dec 26, 2008 | 09:57 AM
  #27
157dB's Avatar
157dB
Cut & Paste Expert
Originally Posted by grampa_stang
What would be the "proper" way to splice into the existing wires in that exact location?
Strip, crimp, solder and adhesive lined heatshrink like OEM.
Then document it in your S197 Workshop Electrical Diagrams
for the next owner to figure out what electrical mods have
been made.
I'm sure it's much easier to undo clips if you wanted to uninstall them.
IDC connectors displace (slice) the insulation and create
a weak spot where one did not exist. Now only the wire
strands are supporting the insulation covered wires.
Mechanical falure is a given over time in an automotive
enviroment. Plus one must use the CORRECT IDC connector
for the guage of wire being tapped. The one size fits many
wire guages approach that the connector manufacturers use
makes the use of an IDC connector even worse.
I think the key word here is 'grandpa'
Attached Thumbnails LED Interior Lighting-headlight.jpg   LED Interior Lighting-img_2985.jpg   LED Interior Lighting-img_3014.jpg
Old Dec 26, 2008 | 10:33 AM
  #28
07musclemustang's Avatar
07musclemustang
ohhh burnt...
but yes soder and heat shrink is the best way to go and the only way i go on my car. (i have done many other ways before and ususaly ended up redoing it)
You did a beautiful and creative install in your car. and F^(K the next owner its your car. do what ever you wanna do with it. and i kinda like the new roof liner.. Im a rag top so not for me.
Also i was looking into the led map lights on ebay how are they for you? which ones did you get???
Old Dec 26, 2008 | 12:13 PM
  #29
rford426's Avatar
rford426
they were bout 15 buck i think
Old Dec 27, 2008 | 04:15 AM
  #30
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
Looks great Ryan.....
